Ford F150 - Brakes Locking up
Old Dec 11, 2010 | 03:38 AM
ackeiyword's Avatar
ackeiyword
I have a 2009 F-150 5.4 SuperCrew 4x4. Four wheel disc brakes.
This morning on the way to work, felt like I had a flat tire. The light that shows the road is slippery came on and never went off. When I stopped to check, tires were fine but I could smell hot brakes.
After letting it sit for a couple hours, went back out and drove it a little to see how it was and I could still feel that atleast one of the brakes was being applied. Believe it is one of the back brakes, steering is not affected.
I did apply and release the parking brake a few times, no help, which ever brake it is, it won't release.
Any ideas?
Thanks
Old Dec 11, 2010 | 04:44 AM
shotgunz's Avatar
shotgunz
If my reading of the owner's manual is correct and I understand your post, it sounds like the TCS or RSC is malfunctioning.
Or am I misunderstanding the symptoms?
If it is malfunctioning you should take it to the dealer.
Old Dec 11, 2010 | 02:19 PM
superrangerman2002's Avatar
superrangerman2002
You may be able to limp it back to the Ford dealer by removing the fuse under the hood for the ABS/TCS system. I think the number is 36, but check your owners manual first.
Old Dec 11, 2010 | 07:47 PM
rgmiller32's Avatar
rgmiller32
Just had the Left Rear ABS sensor replaced on my 2009 Super crew yesterday. Truck was fine on Wed but on Thursday the light was on for ABS and Traction control. Did not notice any dragging brakes but maybe a slight power loss. If both the ABS and Traction control lights are on you have a fault in the ABS system. This will also cause the Traction control to not work properly.
fx4x4
Jul 25, 2016 11:53 PM
hasteranger
Jul 15, 2016 08:40 AM
Jrobole
Jul 5, 2016 11:33 AM
Jeffkolo
Apr 25, 2012 12:29 PM
dpbrowne
Jan 21, 2005 03:54 PM
