Gutting air box
Old Jun 21, 2005 | 09:08 PM
MemOrex's Avatar
MemOrex
Gutting air box
I've been reading some things of people 'gutting' their air box for a little performance gain. I was wondering if anyone has done this to theirs? Would be something for me to do..
Old Jun 21, 2005 | 11:38 PM
RC Dan's Avatar
RC Dan
Any air intake mods you do will have no difference in your trucks performance unless you have done more mods as well. Things like a higher flowing exhaust, performance air filter, ect. must be done along with or before for you to notice any difference.
How ever, there is a somewhat risky mod you can do with the MAF casting that will allow a more snappy throttle response. Go to http://www.roguesecurity.com/ModifiedMAF.html
Many will probably reccomend againts doing this. Be careful if you do. I, myself, have noticed quite a difference after I did this. But, I also have a K&N filter(used, $10 off eBay!!!), no cat. converter, and a 3" exhaust from y-pipe collector to a Flowmaster 40 Series(also used, $10). It may not show as much a difference for you.
Old Jun 22, 2005 | 04:55 PM
EPNCSU2006's Avatar
EPNCSU2006
Gutting the MAF like that is in my opinion a bad idea. It changes the air flow characteristics of the sensor; this difference in air flow is not accompanied by a difference in sensor output voltage, so the mass flow calculation in the computer will be wrong. Whether it is wrong enough to make a difference or not, I couldn't say. It's really up to the owner of the vehicle, but I wouldn't do it to mine. The parts of the airbox that I would think could be cut any would be the end of the inlet pipe going into the bottom of the air filter housing. It has an angled piece with holes in it I suppose to make it more quiet.
Old Jun 22, 2005 | 10:31 PM
frederic's Avatar
frederic
I don't know why'd you gut the maf... it can flow significantly more than your engine can take, in stock form.
Even with a mild cam, the ford MAF is not the bottleneck. Valves, poor shrouding, small exhaust ports, tight exhaust manifold bends, blah blah blah.
Old Jun 23, 2005 | 09:00 AM
MemOrex's Avatar
MemOrex
lol, should've mentioned it was speed-density. i also have the typical K&n filter, no cats, and the flowmaster
redman84
Jul 19, 2010 08:33 AM
MNbandit
May 31, 2010 10:47 AM
c00nhunterjoe
22
Aug 9, 2007 02:11 PM
Mikes92F250
Exhaust Systems
13
Jul 22, 2004 02:46 PM
icebreaker88
24
Sep 1, 2003 09:56 AM
