16.5 Tires
Old Jun 21, 2005 | 07:19 PM
Blu Mule's Avatar
Blu Mule
Cool 16.5 Tires
I own a 1977 F250 4x4 with disc brakes in front. The calipers are so large that I can not use a smaller size wheel on my truck. Recently I found out that this size tire has been discontinued by all tire manufacturers. Just wondereing what everyone else is doing about this situation. Is there a solution like smaller calipers. I do use my truck for what it was designed for.
Thanks Blu Mule
Old Jun 21, 2005 | 07:50 PM
Thomasm67's Avatar
Thomasm67
You can use 16" rims i have a 76 Hiboy with front disk brakes and i put new steel waggon wheel rims on it which were 16's and they fit fine you'll more choice in tires if you do.
Old Jun 21, 2005 | 10:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
My 78F250 is running 16" wheels. There seems to be just enough clearance to run them. I have checked my wheels for a scratch that would come from rubbing while the wheels flex (they do flex a little) and there is none.
Firestone still lists 16.5" tires: http://www.bridgestone-firestone.com/tires/index.asp
You might want to check around some more for those tires. Try a farm store or truck tire store rather than a ricer tire store.
Old Jun 21, 2005 | 10:28 PM
bpatton74's Avatar
bpatton74
Discontinued? I just purchased 4 35x12.50x16.5 BFG All Terrains about a week ago...
Old Jun 21, 2005 | 10:43 PM
Torque1st's Avatar
Torque1st
Posting Legend
I think he went to a ricer tire store and they didn't have a clue about truck tires. If you want a laugh go into one of those places and ask them about changing the tires on your split rims. You get a real "deer in the headlights" look that is hilarious. If you ask them about adjusting the wing on your Civic they will be all over it.
Old Jun 22, 2005 | 01:30 AM
1978fordf250's Avatar
1978fordf250
look in my gallery im going to be running 16inch american racing alluminum rims on my truck fit and look great
Old Jun 22, 2005 | 08:52 PM
rainbowATF's Avatar
rainbowATF
I switched to 16" wheels on 1981 F250 4WD with 245/75R16 tires No problems
Old Jun 22, 2005 | 08:55 PM
docholiday72tx's Avatar
docholiday72tx
Oh lord!!!!
That's hilarious Eric.....it's true...but hilarious!
Old Jun 22, 2005 | 10:11 PM
gier-head's Avatar
gier-head
16 inch rims
My some-what related question is this.......What Ford model years ( and other makes, GM, etc ) can I expect to find 16 inch factory rims on to replace my antique 16.5 rims on my 78 F-350 long wheelbase PU??
I suppose this has been touched on before, but I cannot find it in the search.
Thanks, Dale in KS
Old Jun 22, 2005 | 10:37 PM
IAM.CA's Avatar
IAM.CA
As far as I know, only Ford and Dodge pickups will work, as chevy used a smaller diameter hub pilot, and so the centers of the chev wheels will be too small to fit onto a Ford/Dodge rearend. So Ford rims up to 98, and as far as I know, rims from a new Dodge should still fit.
Old Jun 23, 2005 | 10:18 AM
1978fordf250
Yes chevy hub diameter is a little smaller. they will work ont eh back fine but not the front. to get them to work on the front my dad opened the center of the chevy wheels up on a lathe enough to make them work. but i now switched over to alluminum rims...
Old Jun 23, 2005 | 07:19 PM
deisele75's Avatar
deisele75
http://www.4wheelparts.com/4wp/index.asp
That size is far from discontinued.
Old Jun 23, 2005 | 09:19 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Try to find 33 x 12.00 x 16.5" in radial and highway tread. 9.50 x 16.5 will be around for a long time as this is a common size on small delivery trucks.
.....=o&o>.....
Old Jun 23, 2005 | 10:47 PM
Phideaux's Avatar
Phideaux
16.5" to 16" change what spedo gear?
Another part of this discussion is....
Does anyone know if a new spedo gear ratio needs be used if a person switches from 16.5" wheels to 16" but retains the stock tire diameter?
J.
Old Jun 23, 2005 | 11:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
A speedo gear change is required only when the outside diameter of the tire changes significantly.
