300 wont start
Old Jun 21, 2005 | 07:04 PM
tang93gt04's Avatar
tang93gt04
300 wont start
alright i bought a 70 F250 for a hundred bucks and it wont start. after talking to the guy i bought it from which is a friend, he told me a few things. The truck lost the acc. belt and over heated. It hasnt ran since..... He told me there are plastic timing gears in there that might have melted. Im not familiar with this motor too much and i thought id ask before I tore it apart. It cranks really easy and all it just wont fire. Ive checked the plug wires, the coil for spark and all that small stuff. So if you all have any clue let me know thanks.
Old Jun 21, 2005 | 07:11 PM
DT 466Man's Avatar
DT 466Man
Take off the Oil Filler cap/Breather and check to make sure the Rockers are moving.
It is a really easy motor to work on and runs for ever.'
But this is a start.
DT
Old Jun 22, 2005 | 07:03 PM
tang93gt04's Avatar
tang93gt04
ill give it a try im hoping to head out again this weekend and try a few more things. Id like to get it running and actually get it back to my house. you know if there is any truth in the plastic timing gear thing????
Old Jun 22, 2005 | 10:32 PM
WillyB's Avatar
WillyB
If it got hot enough to melt the timing gears you have a lot of other problems to worry about. I would do a compression check first, that will tell you if it is worth going further. If it has low compression and adding a teaspoon of oil to the cylinder helps in a big way, he got it hot enough to ruin the rings and all you can do is tear it down.
If compression is OK in all cylinders, then you can start trouble shooting.
The fact that you have spark shows the dizzy is turning - which requires the timing gears. Could still have jumped time, but not real likely.
A shot of starting fluid down the carb will check for gas problems - if it starts problem is with the gas delivery, if it does not then you can look elsewhere for the problem.
Most likely the engine is OK and the problem is a bunch of little things that have ganged up on you - things like the spark plug gap, dirt in the carb, bad wires and the like.
But it could be serious so check the compression first.
br0ken d0wn
1983 - 2012 Ranger & B-Series
20
Nov 29, 2018 07:11 PM
texans
26
Sep 2, 2011 05:31 PM
Gravy Train
Sep 19, 2010 12:14 AM
jkdank
Dec 27, 2009 12:13 PM
Matt_in_Mississippi
Dec 31, 2001 01:42 PM
