truck weight
Old Jun 21, 2005 | 05:37 AM
bmcm94's Avatar
bmcm94
truck weight
Dose any one know how much a 1994 f-350 with the 7.3 deisel and long bed regular cab weights in at?
Old Jun 21, 2005 | 06:09 AM
Quadzilla's Avatar
Quadzilla
I've got a 95 Crewcab 4X4, so mine would be slightly heavier, and mine weighs 7300lbs, assuming no one is in it.
Old Jun 21, 2005 | 07:08 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome bmcm94, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 21, 2005 | 08:24 AM
watersurgeon's Avatar
watersurgeon
93' F350 4x4 cc, lb. Half tank of gas weighs in at around 8400.00. You can probably figure about 750-1000 pounds off of that for your truck.
Old Jun 21, 2005 | 08:30 AM
02PSD4ME's Avatar
02PSD4ME
Only sure way to know, is to take it to the scales. Truck weight varies SOOOO much.
Old Jun 21, 2005 | 11:25 AM
tjbeggs's Avatar
tjbeggs
my 95 psd 4x4 supercab long bed with both tanks full weighs in at 6620 pound with out me in it.
tim
Old Jun 21, 2005 | 04:20 PM
arninetyes's Avatar
arninetyes
Yeah, lots of variation in weight. Mine is a 2000 F250, so the weight will be different - but maybe not that much.
Mine is a 2000 7.3, 4x4, automatic, standard cab, long bed, XL - power nothing.
The curb weight full of gas was 6440 measured at a local scale. Yours is an OBS, so the weight will vary. But, the point is, the difference between an XL standard cab, manual trans 4x2 and an XLT crew cab 4x4 automatic can be a couple thousand pounds.
Get it weighed - then, no question.
Old Jun 21, 2005 | 08:26 PM
believer45's Avatar
believer45
'95 F250 power stroke 5 spd 4x2, extended cab, long bed, Putco master boss running boards, aluminum cap on bed (@ 100 lbs), custom rear bumper (@350 lbs additional weight), scale weight full of fuel, me in it (285#) - steer 3420 drive 3160 gvw 6580.
F350 SRW is about 20 lbs heavier, standard cab would probably reduce by 400 - 450, my rear bumper adds 350 to my weight, dually I would guess 500 lbs heavier. 4x4 (you do not say if yours is 2 or 4 wheel drive) adds 450. My guess if yours is dually regular cab 2 wheel drive manual tranny weight is somewhere around 6580 - 350 - 400 + 20 + 500 for 6350 full of fuel. Anything additional for equipment adds to the mix. My weight is with the Power Stroke, in a 94 you may have a Stroke or an indirect injected turbo. I do not think there is much weight difference between them but am not sure. I also do not know what an auto tranny adds.
Dave / Believer45
