Aerostar Ford Aerostar
Windstar Forum??
Old Jun 21, 2005 | 11:42 PM
asavage's Avatar
asavage
FTE Community Team
Stabilizer end links will do that. Impossible to advise long-distance, though.
Old Jun 22, 2005 | 12:18 AM
Racerguy's Avatar
Racerguy
Windstars are famous for clunking front ends. Besides the common problem of sway bar end links that asavage mentioned, I've also seen loose subframe to body bolts, rocks in the springs, worn ball joints, worn tie rod ends etc etc.
Ford also came out with new spring insulators to cure some noise.
Old Jun 22, 2005 | 09:46 AM
CharlestonSC's Avatar
CharlestonSC
I'm taking it in tomorrow to have it checked out. I guess I'll have them check all that's been mentioned thus far, and go from there. With help from you guys and a repair manuel, I've become a somewhat reliable parts-changer, so maybe a diagnosis from a trustworthy mechanic will point me in the right direction. Thanks for the advice.
How much would a set of those spring insulators run?
Old Jun 22, 2005 | 10:48 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Originally Posted by khantyranitar
The Windstars do very well in collisions of all types.
I learned that the hard way. I totalled the Taurus I hit
Cowboy_troy76
General Automotive Discussion
May 31, 2015 02:29 AM
EricGH
Aerostar
Nov 7, 2013 10:41 AM
poorfatkid
1983 - 2012 Ranger & B-Series
Sep 21, 2012 10:52 AM
fordmom
Jan 13, 2004 08:57 PM
