outsite temp unit
Old Jun 20, 2005 | 07:48 AM
K2JJB's Avatar
K2JJB
outsite temp unit
A few days ago my 97 Mountaineer started showing 116deg F as the exterior ambient temp on the overhead display. Per the service manual I have confirmed that I need a new sensor as the resistance at room temp of the current one is too low. I also confirmed that the interior unit is working as it shows -40 open circuit and +140 short circuit.
That said, does anyone know where to get a replacement besides the dealer? I am going to see if I can locate one at a junk yard but would like other options. Does anyone know the Ford P/N for it? The service manual does not have them.
thanks!
-John
Old Jun 20, 2005 | 07:02 PM
Jharger's Avatar
Jharger
Sorry I can't help find a replacement. But if it read 116 down here in Phoenix, it would be accurate.
Old Apr 6, 2006 | 02:21 PM
K2JJB's Avatar
K2JJB
I am hoping to revive this thread... might anyone be able to shed some light on my original question. For a while the temp sensor had an accurate reading again... but it has finally completely died. Electrical checkout per the shop manual confirms that the inside parts are fine and that it is indeed the temp sensing unit at the nose of the truck that is busted.
I even tried going to the dealer and all they were able to come up with was the sensor for a newer model year. The pinout is reversed from that, but I can work around that... what I could not work around is that the little thermocouple inside appears to be for a different temp range so it was off all the time.
thanks!
-John B
Old Apr 7, 2006 | 04:57 PM
Exploder02's Avatar
Exploder02
Just a thought... maybe open up the bad unit and see what parts are bad? Unless it's an all-in-one IC, you might be able to find replacement discrete components to fix it.
Old Apr 7, 2006 | 05:31 PM
df_93_X's Avatar
df_93_X
If you just need the sensor from under the front bumper, NAPA has them for 20 bucks.
Old Apr 7, 2006 | 05:39 PM
njf207's Avatar
njf207
try ponyracer send him a message he might be able to help you out or try cheap ford parts.com
Rudiak
6.4L Power Stroke Diesel
Aug 21, 2017 09:36 PM
jimjokjv
Aug 2, 2017 06:59 PM
Skauber
Dec 26, 2016 11:42 AM
troverman
6.7L Power Stroke Diesel
Oct 21, 2016 09:11 AM
DBGrif91
Jul 26, 2016 07:26 PM
