Clean Headlights!
Old Jun 20, 2005 | 12:32 AM
pulse54's Avatar
pulse54
Clean Headlights!
Ok, so I did some research to see how I could get my headlights looking new again. I had thought about just buying new ones until I found out that you can get them cleaned. So I searched the internet to see what I had to buy or if I could find a how to guide. I ran into an old forum http://www.acura-legend.com/vbulleti...&threadid=1888 There, they talked about cleaning their headlights by wet-sanding them and using rubbing compound to get rid of the scratches. Then finishing up by using plastic polishers. Well that sounded good but there are a few questions I have before following this procedure. First of all, I don't have an air buffer so I don't know what to use or how to do it by hand. Is that stuff hard to take off? What do I use to remove the rubbing compound? Has anyone tried this or another procedure as to polishing headlights? What do you recommend? The headlights look pretty old and I think would make my truck look newer even though its a 95. I'll try to post some pictures later.
Old Jun 20, 2005 | 01:01 AM
Sn0wMan's Avatar
Sn0wMan
So much easier to buy new diamond ones... not to mention youll never get stock to look as good. Ive got pics in my gallery, but if you dont wanna spend money i wouldnt reccommend looking lol.
Old Jun 20, 2005 | 01:18 AM
pfogle's Avatar
pfogle
This is what I did to my '92 E150.. I have some old turtle wax rubbing compound in a tub. I took some blue shop towels and rubbed it into the lens, and then buffed it clean.. The result was about a 50% improvement..
Old Jun 20, 2005 | 03:37 AM
turborich's Avatar
turborich
the wet sanding and polishing works pretty good, however you have to keep up on it. a couple times a year. never as good as new though.
Old Jun 20, 2005 | 07:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Pulse54, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 20, 2005 | 09:30 AM
MemOrex's Avatar
MemOrex
I did that on my headlights. Worked somewhat, but not back to perfect. I might as well dish out $90 for diamond-cut ones, right sn0wman?
Old Jun 20, 2005 | 02:51 PM
pulse54's Avatar
pulse54
Ok, well if it doesn't work I could always buy those diamond ones too. But just to try it out before spending $90, how do you remove rubbing compound if you don't have an air buffer?
Old Jun 21, 2005 | 02:18 AM
TexasGuy001's Avatar
TexasGuy001
I got new replacement headlights off of ebay for about 50 bucks. Here is an auction listing for some. 7980938891 You can just type that number in the search window on ebay. They look just like stock. I decided to go with them insead of the the diamond ones. I think it looks better. Those crystal clear ones always show scratches, pits, and bug stains.
Old Jun 21, 2005 | 02:57 AM
pfogle's Avatar
pfogle
Buff it out by hand.. Sounds like PITA but it only takes a few minutes to do both lights. You only need a small amount.
Old Jun 21, 2005 | 09:52 AM
pulse54's Avatar
pulse54
Ok, this might sound like a stupid question but I've never done anything like this before so could you please explain to me how to buff it out by hand. I'm not sure of what tools I need to do this... sand paper, water, or what? Thanks everyone!
Old Jun 21, 2005 | 10:18 AM
pfogle's Avatar
pfogle
When I did mine, I took a blue shop towel, bought in a roll from autozone, got some of the compound on the towel, and then rubbed it into the lens. I then took a clean towel and just used a circular motion to get the excess off, and polish the lens.
Old Jun 21, 2005 | 11:33 AM
pulse54's Avatar
pulse54
Wow, it's that easy huh? Thanks a bunch! I'll have to post my before and after pictures on here... maybe I won't have to spend so much on clean headlights after all. Thanks again!!
Old Jun 21, 2005 | 12:19 PM
MemOrex's Avatar
MemOrex
Heres what I did:
-Wet sandpaper (fine...1500 grit I think)
-TurtleWax rubbing compoud ( i used a piece of cotton cloth)
-Blue Magic Polish (polished with cotton cloth)
I did this only by hand...It works pretty good.
Old Jun 21, 2005 | 12:38 PM
68torino's Avatar
68torino
A drill with a polishing pad you can pick up from a parts house or major department store. Start with medium pressure then go light pressure for finishing. And yes about twice a year. Basically if they start to yellow, replace.
Old Jun 21, 2005 | 01:12 PM
MemOrex's Avatar
MemOrex
Here is a pic of my lights(there's more in my gallery). Its been about 5-6 months since I cleaned them:
As you can see, the front is pretty clean, but around the edges there is some 'yellowing' that I could not get.
