Offroad & 4x4
suspension question
Old Jun 19, 2005 | 10:40 PM
Marshall_79-f250's Avatar
Marshall_79-f250
suspension question
I'm building a 79 f250 and i bought a 6inch skyjacker kit and i was wondering if i will be able to fit 38.5 inch boggers. if i cant what should i do to get a couple of extra inches. i also bought a body lift but i really dont want to use it . any advice will help thanks.
matt
Old Jun 19, 2005 | 10:44 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
if they are the skinny ones oyu should be able to fit them with no lift and some trimming, and you can fit the wide ones with 4 inches and no trimming
Old Jun 20, 2005 | 06:47 PM
fishmanndotcom's Avatar
fishmanndotcom
send that spawn-of-satan back, esp if you dont want to use it! go ahead and put the tires on. I know they will fit in the driveway. then get the sawzall out and if it needs trimming.... well trim it! when your done either roll the edges back or weld a metal dowel bent to the shape of the wheel well to keep the fenders from cutting the tire up
-cutts-
Old Jun 20, 2005 | 08:21 PM
Marshall_79-f250
i was thinking of doing a shackle flip if it doesnt clear but im not quite sure how to do the front part.
Old Jun 20, 2005 | 09:29 PM
Nigel's Avatar
Nigel
I would say yes. I am setting up my truck with 6" front springs, 4" rears w/ shackle flip and eliminating the blocks. It is sitting on 42" tsls. No bed- hopefully tube after this weekend. I also trimmed the body a lot but only some for tire clearance. I would say you would need minimal trimming with the 38s. It also depends on how wide they are and how much you want it to flex.
Old Jun 20, 2005 | 09:46 PM
Marshall_79-f250
i think im going 11 inches wide. and i dont think i will be needing to much flex this truck isnt going to be a hard core offroading truck it will be an occasional offroader.
Old Jun 20, 2005 | 10:15 PM
Nigel's Avatar
Nigel
My guess is you will be ok but you wont know for sure until it is all together. When I bought my truck it was very a sagged stock suspension with 36" military surplus goodyears and It only rubbed at full lock or turning pretty hard over a bump. I can't amagine a 38.5X11 would be a problem with 6 inches of lift.
Don't be afraid of trimming body if it has some minor rubbing. I think the bushwaker cutout flares are sweet looking on these trucks
Ted
Old Jun 21, 2005 | 03:27 PM
KubotaOrange76
you should be able to fit the skinny 38.5's with 2 inche sof lift and no trimming
Old Jun 21, 2005 | 08:19 PM
Franken-Truck's Avatar
Franken-Truck
Speaking from experience. My '78 F250 has what appears to be the 3.5" lift from rough country on the front. On the street it runs 38x15.5" SS TSL's with out rubbing. It looks like it will hit the front corner of the fender if I turn and hit a curb. Take a look in my gallery for some pics.
Old Jun 21, 2005 | 09:10 PM
Marshall_79-f250
Thanks for all of your information im going to try it if it doesnt clear ill either trim or do the shackle flip thanks alot.
matt
