Strange problem
Old Sep 14, 1999 | 08:36 PM
Snapper_Rider
Guest
Posts: n/a
Strange problem
I have a 84 f150 4x4 with a 300 6 and 4spd trqnny. i was starting it one day and it wasnt starting good so i turned to the key to the run postion. the engine kept cranking. i then turned the key to the off position and it still kept cranking. does anyone know how to fix this problem and what is causing it? thanks
Old Sep 15, 1999 | 07:51 AM
Phillip Guidry's Avatar
Phillip Guidry
Strange problem
The only way that the starter can continue to crank the engine without fireing up,and the key in run or off,is for the starter solenoid to remain either stuck or energized.To test,first remove the small wire from the "S" terminal at the solenoid.Then hook the cable back on the battery{assuming you unhooked it to stop the cranking}.If the starter begins to crank again,remove the cable,and replace the solenoid with a new one.If nothing happened when you hooked the cable,using a test light hooked to ground,probe the "S"wire and notice if voltage is present while the key is in the ACC,OFF or RUN positions,there should be none.There should only be voltage when you cycle the key to the START position{do this several times to make sure it's not intermittent}.If voltage was present when it shouldn't be,more than likely the ignition switch is failing internally,otherwise,there is a hot wire that is fused to the "S" wire.9 times out of 10 it is just a bad solenoid.
Phillip
Old Sep 15, 1999 | 02:48 PM
Snapper_Rider
Guest
Posts: n/a
Strange problem
The starter solenoid was just replaced. My dad thinks it could be something called a return spring in the starter that is getting hung up.
Old Sep 16, 1999 | 07:43 AM
Phillip Guidry
Strange problem
Don't take anything new for granted!I have sold and installed many a defective solenoid for FORD products.They just get stuck and sometimes let go and sometimes don't.If the solenoid has let go since the first incident,and it's not getting energized at the wrong time,it will get stuck again,so be ready.Oh yeah,the "flat" type solenoid {flat bracket instead of "L" bracket}is likely to act up if the battery cable is not installed on the proper post.Refer to the instruction sheet for proper orientation of the battery and starter cables.
Phillip
Old Sep 16, 1999 | 11:09 AM
mustang's Avatar
mustang
Strange problem
datsun147
May 10, 2011 03:01 PM
ridecolby
Aug 11, 2009 07:51 PM
93PGT
25
Feb 10, 2009 09:07 PM
whathappened
Bronco II
17
Sep 9, 2004 06:28 PM
Mr Ed
Electrical Systems/Wiring
Jan 22, 2003 11:06 PM
