Valve Lifter Noise
Old Jun 19, 2005 | 04:41 PM
dorkpunch's Avatar
dorkpunch
Valve Lifter Noise
so i went out to start the truck yesterday and it started real rough- took 4 or 5 tries to get it goin and once it was runnin it took a while for all of the cylinders to catch. It sounds like i've got a noisy lifter, but i cant tell if its my imagination and the crack in the manifold is just worse. The wierd thing is that the day before it ran fine, no noise. then yesterday, it started making the noise from startup. Any ideas what could have caused this? I changed the oil about 5 days ago and used 10w-30. what wieght do yall use in your trucks? should i try something heavier?
Old Jun 19, 2005 | 08:42 PM
4Cammer72's Avatar
4Cammer72
is it backfireing and popping?
Old Jun 20, 2005 | 09:38 AM
dorkpunch's Avatar
dorkpunch
nope. once she was running she ran fine. just a little noisier. i dont think i'm imagining this becuase while going down the road if i let of the gas a bit the noise from the cracked exhaust manifold will go down but the other "ticking" is still there. I had this happend to me before on a chebby 350, but it happened under HARD acceleration. The truck just sat overnight and started rough the next day! Course, on the 350, when i changed the oil it went away after a while... maybe i should try a heavier oil.
Old Jun 20, 2005 | 10:46 AM
4Cammer72's Avatar
4Cammer72
you could have a little junk in the lifter clogging it too. if an oil change doesnt do it for you try a flush in the engine.
Old Jun 20, 2005 | 12:48 PM
ramtoo's Avatar
ramtoo
Add a quart of Lucas oil stabilizer to your 10-30 oil I love this stuff!
Old Jun 20, 2005 | 01:16 PM
bertha66's Avatar
bertha66
If the oil change dose not work for you, pull the valve covers you rock the rocker arm back and fouth and see if one or more are loose.
98range
1983 - 2012 Ranger & B-Series
Jun 23, 2012 07:01 AM
jade79
Jul 31, 2011 04:49 AM
all_smilesjp
1997 - 2003 F150
Oct 1, 2006 03:02 AM
javi2001
19
Jun 1, 2004 08:34 PM
gudoldboy
Oil & Lubrication
Sep 9, 2003 10:22 AM
