volt/ohm meters
Old Sep 23, 1999 | 02:26 PM
Tim M
Guest
Posts: n/a
volt/ohm meters
It appears I'll need at least a volt/ohm meter and vacuum pump/guage to really service my 90 F150 correctly. So what is the best...volt/ohm meter or these multi-meters I see? I'm cheap...but want something as reliable as my 20-year old tach. Any feedback is appreciated
Old Sep 23, 1999 | 02:44 PM
Phillip Guidry's Avatar
Phillip Guidry
volt/ohm meters
Lets state the differences first;A VOM is an analog type{needle swing} meter,a DMM is a digital type meter.You can gather codes from the computer with a VOM but not a DMM{unless the DMM has audible check}.A decent VOM will cover everything,including diode checks by simply reversing the connections.The MAIN thing I like about a DMM is the ability to view a component that is not showing a steady reading by the fluctuation of the digits on the display,indicating an unbalance,no matter how small it is.VOM's have a "buffer" I guess that holds the needle steady over a certain range,making it seem as if the component is not "falling out".Check out Sears,Radio Shack,Ace,Home Depot,etc. for pricing/availability.
Phillip
Old Sep 23, 1999 | 02:48 PM
Phillip Guidry
volt/ohm meters
vettman
21
Jan 8, 2009 09:47 AM
cato47
Aug 3, 2006 11:19 PM
joeblow972
Apr 6, 2004 11:26 PM
shoogdoog
Jul 5, 2003 08:55 PM
dano14
Mar 15, 2002 05:36 PM
