1978 - 1996 Big Bronco
error code 87
Old Jun 16, 2005 | 01:32 AM
norcalcapri's Avatar
norcalcapri
error code 87
all of the sudden out of the blue, my 88 bronco xlt 4wd 302 started running rather rough. it gradually got worse to the point right now of it taking about 10 tries to get it to fire up. when I give it gas, it bogs down to the point of dying if i give it too much gas. if i slowly rev it up its ok. smells like its really running rich. im getting a spark at all of the splugs, so were good there. pulled a code 87, primary fuel pump circuit failure, but its not tripping the light. could the pump be the culprit? also, which pump is considered the primary one? Thank you guys very much for your time and all the help youve given me thus far!
-Tony
Old Jun 16, 2005 | 04:58 PM
norcalcapri
also bled the fuel line and there was quite a bit of air bubbles in it. and checked whole line for leaks, none. tank was really low, so i put 5 gallons in it. checked the plugs, and they are fouled as hell, and theyve only been in there for like 400 miles. after the pump primes the system, pressure is at about 32psi, shouldnt it be higher?
61steven
May 14, 2016 09:58 AM
wtroger
Dec 18, 2015 10:13 PM
Monty06
Bronco II
Jul 21, 2005 12:01 AM
Flash
Oil & Lubrication
Oct 7, 2004 03:30 PM
jrautali
Jul 11, 2004 09:31 PM
