Code 21 ECT
Old Dec 18, 2015 | 10:13 PM
wtroger's Avatar
wtroger
Code 21 ECT
Wanted to pass this on. My 1989 f-superduty 460 5 sp. recently wouldn't idle down. Wanted to idle at 1500-2000 rpm. check for vacuum leaks none found. Tested IAC and it passed. It finally got where it wouldn't run unless really wound up. If it died I had to start it like it was flooded and it was. Finally crippled it home. Ran the codes got a 21 a 33 and 87. the 21 ect out of self test range 33 no egr movement that ones been there a long time 87 primary fuel pump circuit failure. That couldn't be true it was suffering from to much fuel. Replace the ECT and everything was back to normal. Idles at 900 rpm runs fine. I would have never though that a coolant temp sensor could cause an engine to run this poorly.So just an FYI for others.
joedangelo04
Feb 12, 2017 02:08 PM
couchsachraga
Jun 5, 2015 04:38 PM
gene_sc
Feb 2, 2010 08:09 PM
el conquistador
1983 - 2012 Ranger & B-Series
18
Sep 17, 2004 10:15 PM
bufordt
Mar 14, 2002 04:23 PM
