1978 - 1996 Big Bronco
two alternators
Old Jun 17, 2005 | 06:40 PM
SoFla David's Avatar
SoFla David
Originally Posted by masseysbronco
the capacitor will help. a winch pulls an enormous amount of amperage, obviously more than your altenator can put out at once. when the winch is running the cap will help keep the voltage at 13-14V, which will lower the amount of current necessary. ...
Massey, Double check your research. The current stored in a capacitor like the ones you find at a car audio shop would be depleted by a winch in less than a second.
A capacitor big enough to maintain the winch working for more than a couple of seconds would be so big it would need to be towed behind the truck on a trailer.
Like I said, a capacitor is good to smooth out the Surges from a device like an audio amp, or a flashing light, but for a steady high amp draw like a winch, It would do nothing.
And even in car audio applications, the Capacitor mainly compansates for the resistance of the wire run from the batt/alternator to the amp. I've yet to see an amp that draws more than 70 amps (the output of a typical alternator)
I'd hate to see this guy go out and spend money on something that he doesn't need.
If you have documentation proving otherwise, please let me know so I can go back to the University and throw my Electrionics Engineering degree at the proffessor, LOL
Old Jun 17, 2005 | 08:02 PM
masseysbronco's Avatar
masseysbronco
Lightbulb
I bow to your talents sir. What about installing a capacitor for his accessories? That would at least help keep the lights bright wouldn't it?
Old Jun 17, 2005 | 08:10 PM
bterry's Avatar
bterry
If you install dual batteries in series, (+ of one battery to the + of the other battery and the same for the negatives) both batteries will act as one giant battery sharing the load, and both getting charged at the same time. Thats how i have mine setup, and i haven't had any problems, (i don't even have an aftermarket altenator yet).
Just to be correct, thats parallel - not series. MasseyBronco does suggest a good way to hook up the batteries though.
Old Jun 18, 2005 | 12:12 PM
big1992bronco's Avatar
big1992bronco
hey thanks everybody, i found a kit that optima has, it has the brackets the cables, battery, basicly everything needed. it basicly takes and makes one big battery, hopefully this fixes everything. thanks
Old Jun 18, 2005 | 01:03 PM
masseysbronco
Thumbs up
Good luck let us know how it works out!
Old Jun 19, 2005 | 12:52 PM
Kemicalburns's Avatar
Kemicalburns
you should still look into a larger alt. two batterys is more of a bandaid
Old Jun 19, 2005 | 12:54 PM
big1992bronco
already have a high output alt.
Old Jun 19, 2005 | 01:14 PM
Kemicalburns
what is it? i dont recall you saying what it was. you should have at least a 130+amp and what kind is it. a 130 or 200amp 3g alt would handle all you have to dish out for sure. check out www.fordfuelinjection.com for premade harness's and large fuse blocks to make this an easy install as possible
Old Jun 25, 2005 | 07:59 PM
redrumybronco's Avatar
redrumybronco
Jeff:
I agree with kem on this about going with a larger 200+ amp alternator, but If you go the dual battery setup just be sure that if connecting your batteries together in parallel (or even in series for that matter) that both batteries are of the same age and group size. Now if you are planning to isolate them from each other then that shouldn't matter unless you will have a switch of some kind to connect them when one or the other is drained. This little project can be quite costly and should be good for the rated life of the batteries only (when done properly) and then you have two more batteries to replace... Good luck and may the force be with you!
btw: nice looking bronco, I like what you did to it overall, good job.
Old Jun 26, 2005 | 06:44 AM
bterry's Avatar
bterry
Exclamation
This is probably a well known fact, but just to make sure nobody fries thier truck, DO NOT hook up automotive batteries in series. You'll get 24 volts - enough to fry just about everthing in a vehicle. Big diesel trucks will use 24v for starting, but not any light car or truck that I know of (Superduties are a light truck too).
Sorry about posting the obvious.
Canadianice
Dec 11, 2011 08:39 PM
dgalloway
Jan 5, 2005 08:27 PM
Van Abbott
Jan 3, 2005 05:59 PM
007bronco
Aerostar
Nov 21, 2004 03:23 PM
StrauntonBronco
Apr 23, 2003 11:06 PM
