dimmer switch problem
Old Jun 15, 2005 | 11:07 AM
karlg's Avatar
karlg
The house that my wife and I purchased last month has a dimmer switch controlling six recessed lights in the living room. When the lights have been on for a period of time the switch and coverplate are hot to the touch. The lights are in the cathedral ceiling and I haven't had a chance to check the wattage of the bulbs. It seems that most of the dimmer switches that home depot sells are rated for 600 watts, so I "expect" that this one is also. So...how should I trouble shoot? Where to start?
Thanks,
Karl
Old Jun 15, 2005 | 11:19 AM
fred_79f250's Avatar
fred_79f250
Dimmer switches absorb power, especially when the lights are dimmed. So they will always get warm to some extent. But the heat wears them out, so it's a self-accelerating process - the more it heats, the more it wears out, so the more it heats, so..... until eventually they overheat. Left too long they become hazard. Check the associated wiring for heat damage. You may just have an old tired dimmer that needs replacing.
Old Jun 15, 2005 | 11:32 AM
karlg's Avatar
karlg
Thanks Fred. I'll check the wiring for heat damage. I'll also check the wattage on the recessed lights and make sure I purchase the correct size dimmer. Never had a dimmer and so no experience.
Thanks again,
Karl
Old Jun 15, 2005 | 12:01 PM
CTford's Avatar
CTford
Just had to replace mine- yes they get warm, but it shouldn't be a problem. They're cheap- under $5 bucks.
Just remember to shut off the power before changing it!
Old Jun 15, 2005 | 01:18 PM
Bruker's Avatar
Bruker
Dimmer switches don't last very long when they're used at or above their rated capacity. When they overheat they'll emit an pungent smell. If I were you I'd try to find a switch rated higher than what the actual load is.
Old Jun 15, 2005 | 01:37 PM
sierraben's Avatar
sierraben
Get yourself a heavy duty dimmer switch, probably from a speciality lighting store.
They're expensive but worth the extra money.
I wouldn't get those cheapo $5.00 dimmer switches.
A friend of mine (electrician) installed a pair of dimmers, using those cheapo's.
They got pretty hot.
He had to replace them a week later with the heavy duty type.
IMHO, better safe than sorry.
It's your house.
Old Jun 15, 2005 | 11:18 PM
Crash687's Avatar
Crash687
if you look carefully you can find 1000 watt rated at Home Depot or Lowe's
http://www.lowes.com/lowes/lkn?actio...-WH&lpage=none
Old Jun 16, 2005 | 02:52 PM
karlg's Avatar
karlg
[QUOTE=Crash687]if you look carefully you can find 1000 watt rated at Home Depot or Lowe's
Great! That should be easy enough to find. Karl
Old Jun 16, 2005 | 10:12 PM
BOJOFASO's Avatar
BOJOFASO
i think even with a 1000 watt dimmer the switch will still get warm especially if the lights are kept dim.
Old Jun 17, 2005 | 02:17 AM
pfogle's Avatar
pfogle
Remeber this, if a 100 watt bulb is dimmed to 50% output (50 watts) the dimmer becomes a resistor and creates heat, it may even pull twice the current as a 100 watt bulb.
Old Jun 17, 2005 | 05:22 AM
glafond's Avatar
glafond
A dimmer switch works by clipping the ac sine wave as it passes past 0 volts, in both directions. it's not dimming the light by resistance, but by voltage regulation. I just wanted to mention this because i just recently read that the number 1 electrical fire hazard in the home is a high resistance connection. this is a receptacle or light switch that has either a loose connection or wires butt spliced or wire nutted together poorly.
this causes a LOT of heat in an electrical box.
be safe, no switch or receptacle should be allowed to get more than slightly warm to the touch.
Old Jun 17, 2005 | 05:40 PM
Greywolf's Avatar
Greywolf
6 x 150 = 900
This is the max you can probably expect in household lights.
900 x 150% = 1350
This is the wattage of the switch you should have as a safety margin (30% of the rated capacity)
FWIW
~Wolf
PS: Ensure that it is seperately breakered - I would.
PPS: Check the bulbs for the rating.
ford2go
Apr 3, 2011 05:35 PM
FTE Herman
13
Jun 5, 2004 10:17 PM
TallPaul
18
Aug 20, 2003 07:29 AM
