Just added new filter !
Old Jun 16, 2005 | 11:01 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
I Also Have A K&n Filter Kit. Kind Of Pricey But Overall I Am Satisfied. Sounds Like Darth Vader Exhaling After Letting Off The Throttle While Driving. Also Have 4" Exaust Turbo Back.
Old Jun 17, 2005 | 10:53 AM
edub32's Avatar
edub32
Is that the only 4" cone filter K&N makes or do they make a larger one with a 4" inlet?
Old Jun 17, 2005 | 11:12 AM
4X4 IN REFUGIO
It,s The 4" Inlet Cone Type Filter. Already Has Hole On End Of It For Your Filter Minder.
Old Jun 17, 2005 | 11:27 AM
muddog899's Avatar
muddog899
here is k&ns web site the filter that i use is the
http://www.knfilters.com/search/univ2.aspx?ID=S0013
RC 4780
but you could also use this two also
RE 0870
RF1027
I went with the 4780 because it had the stud all ready attached and had the hole for the filter minder if i remember right it fits an late 1990s model f 250
i just need to build a box for it it gets a litle loud sometimes pulling a heavy load up the mountains
with this filter an adjustable 10K pot and 4in exhuast it will move out
Old Jun 17, 2005 | 02:15 PM
Max1775's Avatar
Max1775
If you're looking fo larger filters, Check out the RU-5045 (cone) or RD-1460 (round). They're about as big as you can get....
Max
dalefuji
Air Intakes, Air Filters & Ram Air
Nov 11, 2018 04:52 AM
drh1175
Mar 17, 2017 01:22 PM
Dan Kacz
1978 - 1996 Big Bronco
Mar 8, 2017 07:33 AM
Tnriverside
2009 - 2014 F150
Mar 11, 2016 08:50 AM
NMSU_RRAggie
Jan 11, 2016 07:24 PM
