Predetonation
Old Nov 2, 1999 | 07:13 PM
jason's Avatar
jason
Predetonation
I just recently moved to southern Missouri from South Dakota and my 86 F-150 with a 351 HO with 68K miles started pinging when I am going up a hill. Never had this problem in the black hills of south dakota but these hills around here are causing alot of pinging. Other than the pinging the truck runs great. Any sugestions would be greatly appriciated.
Old Nov 3, 1999 | 08:43 AM
slik's Avatar
slik
Predetonation
Where in MO did you move? I grew up in Eastern South Dakota, lived in the Black Hills for a number of years and lived in Southern MO for a couple (West Plains). Two things to try on the pinging, one: use a higher octane gas; It seems to me that different regions have different quality gas or at least the additive that they put in the gas or two: advance (? I think that's the correct word) your timing; You're probably running around 12 degrees BTDC and you may need to advance to 10 or even 8 degrees. I think the humidity must also play a big roll in determining your driving power. I put in an adjustable timing module from MSD so I can adjust my timing from the cab between 4-24 degrees BTDC.
Slik
Old Nov 3, 1999 | 01:46 PM
dg's Avatar
dg
Predetonation
I am moving my family to Rapid City,SD on 11-10-99. Is there any advise you could give me? Thanks
DG
Old Nov 3, 1999 | 01:50 PM
H8monday's Avatar
H8monday
Predetonation
Slik,
Going from 12 degress to 10 or 8 degrees would actualy be retarding the timing,but you have the right idea.the timing should be retarded in 2 degree increments until the pinging stops.It should be adressed quickly as pre detonation is very bad for an engine.
Jeff
Old Nov 3, 1999 | 07:12 PM
jason's Avatar
jason
Predetonation
I retarded the timing from 10d BTDC to 8d BTDC switched from 87 to 92 octaine and Every thing seems good time will tell. thanks for all your help.
Old Nov 3, 1999 | 08:25 PM
Bent6's Avatar
Bent6
Predetonation
A non fuctioning EGR can cause part throttle pinging. The EGR dilutes the air fuel charge with exhaust gas. This lowers combustion temperature to control oxides of nitrogen and lessen the chance of pinging. Even if this is your problem, it may be easier to stop by retarding timing or buying higher octane fuel.
Old Nov 5, 1999 | 07:49 AM
slik's Avatar
slik
Predetonation
Yeah, I always get them mixed up. It's tough working on my engine when I don't know what I'm talking about!!
Slik
Old Nov 5, 1999 | 07:53 AM
slik's Avatar
slik
Predetonation
DG,
Congratulations, I used to live in Rapid. It's the most beautiful area I've ever lived, but I can't seem to ever make any money there.... Hey, the Black Hills area is fairly dry, not arid, but certainly less humid than the rest of the state, and your running at several thousand feet. If you're into the Hills at all, you'll be running a mile high most of the time. I believe you would want to run at 12-15 BTDC under those conditions. And (I still have relatives back there) maybe I'll see you next summer when I visit.
Slik
Old Nov 6, 1999 | 03:10 PM
shawn donkin's Avatar
shawn donkin
Predetonation
