79 4X4 Towing
Old Jun 15, 2005 | 10:32 AM
MBBFord's Avatar
MBBFord
You made a good choice. If your be towing mostly under 40 mph the 300 is best for you.
Good luck with everything,
Matt
Old Jun 23, 2005 | 11:09 PM
jasond5150's Avatar
jasond5150
I too have a 79 F150 4x4 and am not surprised that it is capable of pulling over 7,000 pounds - it's the stopping part that scares me - maybe that's why the owner's manual rating is so low??
Old Jun 24, 2005 | 12:53 PM
yonu's Avatar
yonu
how about a brake controller? and as to the steering box why not just have it rebuilt? we had ours rebuilt by the auto shop at the local college havn't had a problem with it yeat
Old Jun 25, 2005 | 02:51 AM
roger dowty's Avatar
roger dowty
I think the rating was so low due to the low hp/torque of the 351m in those years. I would consider going to a beefier brake system - maybe - but the 300 is a great motor- I've owned a couple. trailer brakes would be very important and keep an eye on the tire wear in the rear as heavy lods will bend a 9" rearend overtime.
Also look at what you can do to that 300 to beef it up as well- used to be an indy engine after all.
Old Aug 17, 2005 | 09:28 AM
Snowman671's Avatar
Snowman671
Well guys,
got the new steerign box on, hooked up some elec brakes. Tows good need to get equalizer hitch but other than that pretty nice, the 300 has enough to keep moving and only bogs abit on the hills. I been out 2 times in it and doing fine. Can tell I'm pulling the trailer.
Thanks for all the help. !!!
Anyoen know a good place to get the steering shaft between the gearbox and the column please let me know. The U-Joint there is totaaly trashed from the last guy that owned it and I don't think that just the u-joint is replaceable
Thanks !!
Dave
Old Aug 18, 2005 | 02:10 PM
catmandu79's Avatar
catmandu79
Some states have laws against overloading your truck. The point, if you put 20lbs. of crap in a 5lb. bag eventually it will break!
Old Aug 19, 2005 | 07:40 AM
Snowman671's Avatar
Snowman671
If the truck is rated to tow 7000 LBS with a v-8 then the truck itself can still handle the same amount of weight and towing with the 300. power differnces will exist but it does not change the way the truck was built.
only reason for load equalizer was to smooth out the bumps in the road. the truck does not squat more than 1/2" under the load..
Old Nov 10, 2005 | 04:57 PM
toolz_not_toyz's Avatar
toolz_not_toyz
Towing capacities
I know this is a pretty late followup but it might be useful information for anyone else that stumbles across this thread. I came here looking for some insight on trailers and these old trucks too. I have a 1978 4x4 with a 460. I also happen to have a copy of the 1978 owners' manual.
The manual indicates this:
Class 1 trailer + weight carrying hitch = 2000lbs
Tongue Load = 10-15% of trailer weight, max 200lbs
Class 2 trailer + weight distributing hitch = 2000-3500lbs
Tongue Load = 10-15% of trailer weight, no max indicated
Class 3 trailer + weight distributing hitch = 3500-6000lbs
Tongue Load = 10-15% of trailer weight, max 800lbs
The engines in this case are either a 351 or 460. This info is correct for either shortbed (117") or long bed (133"). I hope this helps anyone looking for this information. Keep in mind that the brakes on these trucks are what they are vs what you would have using a newer truck to haul a heavy load around with.
Old Nov 11, 2005 | 01:27 AM
roger dowty
the 460 was not an option in '78. Just the 351m or 400.
leroys4wd
1997 - 2003 F150
18
Jul 28, 2022 01:23 PM
Camper Special Gene
Feb 14, 2014 07:27 AM
sgrizzle
2009 - 2014 F150
Mar 29, 2013 05:26 AM
new camper
Dec 4, 2011 08:04 AM
Mac Daddy
Modular V10 (6.8l)
Jul 28, 2011 12:02 PM
