Gauge Light Upgrade
Old Jun 13, 2005 | 12:43 PM
stephenw's Avatar
stephenw
Gauge Light Upgrade
Periodically there have been posts here about the miserable green dash lighting in our 70s trucks. I thought I would pass along a possible fix.
I favor red back-lighting, so after removing the murky blue-looking filters from inside the gage pod, I installed two 5LED Matrix #194 lamps from www.superlumination.com/194.htm They work great, nice and bright when you want, and they dim very nicely too, plus you have have a good selection of colors. I earlier tried red #194 incandescents and other single LED lamps, and I can say "forget that", as they simply aren't bright enough.
Unfortunately I wasn't able to figure out an expedient way to change out the backlighting for the light/wiper switches nor heater controls due to their design, but at least this makes the part of the dash you are always looking at much friendlier.
JFWIW. Steve
Old Jun 13, 2005 | 12:48 PM
Mil1ion's Avatar
Mil1ion
This fix has been mentioned in numerous Cluster Lighting threads.
I think it is mentioned in the tech articles.
As much as we appreciate the contribution,this thread will be on page three by tomorrow.
I moved the last post like this to the tips & tricks thread.
Again, Thank you
Old Jun 13, 2005 | 12:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
The military seems to use red light for night vision and they must know something. Thanks for the information.
Old Jun 13, 2005 | 02:10 PM
Purely Ford's Avatar
Purely Ford
This is an entirely different topic but, truck drivers know about it too. They will use a red light mounted under the dash somewhere to give off a small amount of interior light. The reason I get told is it helps to see better at night. Thats all I know about it, but it is popular with drivers in some areas. I've even been told that blue is used as well.
Old Jun 13, 2005 | 06:22 PM
SasquatchF-250's Avatar
SasquatchF-250
red light is easier on the eyes for them to adjust. I worked on a ship and the pilot house was filled with red light.
Old Jun 13, 2005 | 06:29 PM
Amtek's Avatar
Amtek
I've put a 4 Amber LED bulb for the turn signals inside the cluster and even with the green film, they shine bright and clear amber and was easy to see if they're on even with the sun shining directly at them.
Im indecisive on wether to put amber, red, or 'super'white LED's for the guage cluster.
I put a superwhite LED in the Headlight/Windsheild Wiper lens...thing. Had to rig up something to hold the LED in, so its in there temporarily. Looks real sharp, But i'll change it to whatever color the Guages will be in the end.
Cant decide on the paint color either, Between keeping it white or painting it craftsman tool box red (or slightly darker than fire engine red) while the grills, bumpers, roll bar, wheels, aux lights, etc are all black. This will determine the guage colors.
Old Jun 13, 2005 | 08:24 PM
bulrydr_1's Avatar
bulrydr_1
Partially correct.... for night driving under blackout conditions (minimal to no lights) we use red, but on the majority of or tactical trucks, the dash lights are the same color as the one's on the dealer lot. We are only allowed to use the red, which is a whole new circuit and switch, for tactical conditions for safety reasons. Blue is also gaining popularity for night vision as well.....
Old Jun 14, 2005 | 01:13 PM
1978fordf250's Avatar
1978fordf250
Hey I was wondering what kind of bulb does the heater assembaly take? Does anyone know? I knwo the wiper and ligth switch light is a 1445 in my truck but i dotn know what the heater assembaly is. Please let me know. Also anyone know what the turn signals are? I would liek to change all of mine over because the bright red paint would match red guages alot better.
thanks,
Jimmy
Old Jun 14, 2005 | 03:16 PM
Mil1ion's Avatar
Mil1ion
If my Memory serves me correctly that would be the # 161 bulb for the heater control illumination.
TS= 194's
Transmission gear light:
Non-Tilt = 161
Tilt column =1445
Old Jun 14, 2005 | 09:17 PM
yonu's Avatar
yonu
anyone know where to get eh 1445 bulbs in LEDs?
Old Jun 26, 2005 | 11:19 PM
1978fordf250
Hey I was wondering I just put the same bulbs into my truck. I put 2 of them in for the backing lights and I also put one in for each turnsignal(after i took the green lense out of turn signal). This made my turnsignals bright red and the color matches my truck very nicely. The only problem I noticed was the fuel guage and the far left panel on my dash was dim and hardly noticable almost black (talking about the left square out of the 3 in the bezzel itself) not the wiper/light switch. Do you have any ideas why that side would be dim liek that?
thanks,
Jimmy
PS was that dim on yours also? Please let me know!
Old Jun 26, 2005 | 11:37 PM
Mil1ion's Avatar
Mil1ion
Was the white cluster back cracked or broken?
That would cause light leak.
Old Jul 6, 2005 | 04:20 PM
yonu's Avatar
yonu
ok all if anyone is intresested i have found out how to upgrad the bulb behind the headlight/wipers labels goto your local salvage yard and get a socket fromt he cig ligher in a newer ford or other car that uses that bulb they will clip into the mount for hte stock socket and you just have to splice it inplace of the stock one still working on the gear selector ont he column
