I'm sure this has been covered, but I couldn't find it doing a search.
My 66 F100, according to the door panel, came with a 240. However, I know that the previous owner (my wife's grandfather) had a different engine put in the truck about 12 years ago. Is there a stamping on the engine that would tell me what engine it is (it's either a 240 or a 300), and more so, what year the engine was manufactured?
In taking out the radiator today for replacement, I noticed a brass tag on the front of the engine, near the fan. Would that provide a clue?
There should be a # on the side of the block, basically between the starter and the exaust manifold. The # should begin with something like C6TE or D5TE. All you can tell by that is the decade the block was cast in, as well as the year.
I believe the only way to tell the two engines apart is to measure the stroke.
Suppose to be, but rarely is, an 'engine identification tag' located under coil attaching bolt, or sometimes distributer attaching bolt. Had simular issue with engine in my 65. Came across article explaining the displacement is gained in the stroke. The 240 measures 3.180, and the 300 measures 3.980. Possibly I.D. thru 'engine assembly No.' and don't have a clue where it is located on the 240/300. Should look like C6TZ 6007 (and a letter). Perhaps more knowledgeable member can explain.
dave
Clean the tag off and see. It's most likely a rebuilt unit and that tag may tell you engine size and what size the bearings for the crank are.A Ford casting number will only tell you era as above post says. It won't pin it down to exact year. Ford just didn't do that. Most rebuilder used what ever block that would work, regardless of actual year. That 240-300 series blocks had a long span (65-89) and yours could be somewhere in that time frame.
A Ford casting number will only tell you era as above post says. It won't pin it down to exact year. Ford just didn't do that.Barry
The Ford casting number is supposed to break down to year, and decade. That is the purpose. For instance the number on my 300 is D5TE-----. I forget the numbers after E. The first digit D is for the decade, D is for 1970's. The second digit is the year, so D5 would be 1975. I'm not sure but have read that TE stands to Truck-Engine.
If all this is true a 1960's 240 should have a block number beginning with C5TE------,or maybe another year like C8TE.
Still in all this will not help tell the difference between the 240 and 300.
No, it will not break it down to exact year. You are right about how you broke it down, by the last 300 6cyl engine were used up until the late 80's. They didn't change the casting numbers each year. Only when some modifacation was made to that block. D5TE casting were changed at that point because of unleaded fuel coming into existence. Same for the head that year. Look at the 223 engine, they stopped in 64 and all from 63 on had C3AE casting numbers. I'll repeat it, You cannot tell the exact year from a casting number.
D5TE casting were changed at that point because of unleaded fuel coming into existence. Barry
Does that mean my D5TE engine was made to use unleaded fuel? If so that is good as far as I am concerned. I always thought it was just a 1975 engine. Now I see I have been somewhat mistaken. Live and learn.. I have never been sure 100% what I have. Guess I never will be. Oh well, no matter because it runs great, and is dependable. Thats what really matters......
The 300 was avalible in all ford trucks as the base engine untill the introduction of the triton in mid year 95 with the introduction of the 96 new drop nose F150s.
I have a junk F4 block sitting in the corner awaiting the scrap man
There were 2 mold changes on the 300 6cyl. In 75 they made changes and also in 87. In 87 they eliminated the opening for the mechanical fuel pump. This was the year they started fuel injection on them. So, basically, what they did was make a mold with the casting numbers on it and made a ton of these engines, all using that mold. Then when they made thier updates, the new molds reflected the changes with a new casting number.
My guess, though I haven't checked it, is that the engine is a 300, just because they were so much more common over a longer period of time, than a 240.
I'm sure this is a boring topic, but please bare with us novice, does this id rule apply to the small block 302 and 351W also. The location of cast number I mean?
Don't think this helps but the only exterior differences in my 66 240 and my 74 300 that I can tell was the implacement of the oil pan drain plug; both have all originial parts and I'm sure thats not a true 'identity difference" for the two engines of mine.
Boy did Henry & clan us the K.I.S.S method...
