Gear Vendors shifting?
I'm thinking about getting a Gear Vendors unit to put behind my 460-C6. I mostly want it for the overdrive to help with highway speeds and gas mileage, etc. But I can't find anything specifically stating how the setup shifts. Will it automatically shift gears for me or will I need to do it manually between gears or into overdrive and all?
I've also considered a newer transmission with overdrive instead, but I'm told they aren't very sturdy. (I believe it's the E40D or something?) Could I buy one and have it beefed up for possibly cheaper? Maybe find one that's already blown up or something and then have it rebuilt to be stronger?
-J.Banks-
-J.Banks-
I have an older Doug Nash overdrive unit behind my C-6 in my '66. It was the parent of the US Gear OD, which is similar to the Gear Vendors one. They both are 2 gear transmissions only - straight drive and OD.
You have to tell it when to shift via a switch setup.
I do not know how the GV unit works, but the Nash unit has a gear motor inside, turning a worm gear. This worm gear moves a pawl back and forth into or out of OD and straight drive.
I am happy with mine. I bought it used, and had to find the connectors for the wiring where it plugs into the tranny; they are mid '70s GM grey 2-prong connectors.
I wired up the relay, and a switch system I found in an old bus. It had red and yellow lights (one for straight and one for OD) already wired up. Looks vintage too.
I could have bought the entire wiring system for $400, but this was a LOT cheaper.
I have never checked out my mileage. My Nash OD was behind a tired 352 and an LTD C-6, so my mileage and performance was pretty poor.
I blew the 352 in my '66 last December, and am near the end of an engine/transmission swap of a 460/C-6. I'll have the better power while in OD, and I hope to gain better highway mileage as well.
Hope this helps.
Hope this helps.
I forgot to add that they show up on Ebay frequently. Even if you bought one new, I believe you would be ahead of the game to do so, rather than go through all the trouble to adapt a different transmission to your vehicle.
I am not saying it cannot be done, this would be a lot easier and faster, and almost as economical to go with the US Gear or Gear Vendors unit.
Check the horse's mouth:
http://www.gearvendors.com/faq.html
You can check these other boys out regarding AOD and E4OD set ups.
Gear Vendors is $2500 or so, but will be a cooler set up. AOD and E4OD give you the lockup converter that helps save gas as well.
http://www.transmissioncenter.net/AOD.htm
http://www.baumannengineering.com/aodcat.htm
http://ckperformance.com/ford_aod.html
http://www.tciauto.com/ford/ford_aod.htm
Yeah, I read the Gear Vendors site you referenced but they didn't answer the question that clearly. I seemed to gather it would shift automatically but I wanted to be sure cause it really doesn't say it clearly.
Thanks for all the input. I've been watching the overdrives on ebay. I don't know that it would be much more trouble to convert to that newer trans than the gear vendors, I'm just worried it wouldn't be tough enough from what people say.
-J.Banks-
-J.Banks-
well the way i understand it, if u put it on automatic it will automaticly shift into od at 47 mph, and then shift back out at a slightly lower speed. if u switch it to manule u can choose to shift it when u want it to shift. hope that helps
i would go with the us gear unit to the other gear vendors unit u cant shift under load.
karljay
17
11-24-2015 07:49 AM
Family Hauler
18
08-14-2015 05:52 PM
Dano78
15
03-25-2011 07:22 AM
oldfordtrucksrule
07-25-2006 06:54 PM
