high rpm's...
Old Jun 11, 2005 | 11:27 PM
CathyT's Avatar
CathyT
high rpm's...
3.0 v6 XLT '89 Ranger
When disengaging the clutch or in neutral the RPM's go up to and stay around 3k until my tires are completely stopped. Once I come to a complete stop the rpm's go to normal...if I was to start passively rolling the RPM's go right back up to around 3k?
Dealership changed the air intake sensor, this did not help the problem. This problem happens 99% of the time. Once in a while it will not happen but then the next stop sign or light it will happen again.
I cannot figure out any pattern to when this happens and when it does not.
Thanks for any help.
Old Jun 12, 2005 | 06:43 AM
Rockledge's Avatar
Rockledge
My initial thoughts would be a problem with the idle air control valve or the throttle position sensor.
