Intercooled Supercharged V10
Old Jun 25, 2005 | 12:07 PM
  #31
Blurry94's Avatar
Blurry94
BFGoodrich and Nitto make drag radials that hook quite well on the street and strip. They will ride/perform much like everyday rubber but they wont last as long.
Hoosier and M/T both make a DOT approved slick. They hook just like race slick and they have a couple of grooves cut in them so they can be classified as a DOT approved tire. This type of tire will have the shortest life, but it will hook the best. However, I wouldn't want to get stuck in the rain with these so a drag radial might be more your speed. You'll have to shop around for pricing since it varys so much from one retailer to another
I like the way Toyo tires perform on a truck as well. I drove a GEN 2 Lightning with a set of them on there and they did ride/bite quite well I might add...much better than the Goodyear tires I have on my GEN 1 right now.
Old Jun 26, 2005 | 12:28 PM
  #32
F150daniel's Avatar
F150daniel
Drag radials
The Nittos would work best for you, they have the best wear.
The M/Ts stick the best but wear the fastest.
BFGs wear faster than Nittos but stick better.
Old Jun 26, 2005 | 01:21 PM
  #33
skipperw's Avatar
skipperw
Please show a link that show drag radials for trucks. What is the load and speed ratings of drag radials
Old Jun 26, 2005 | 02:57 PM
  #34
Blurry94's Avatar
Blurry94
The 315 and 295 series tires run $137.50 through Summit, these tires are about 30" tall.
Old Jun 26, 2005 | 03:14 PM
  #35
skipperw's Avatar
skipperw
Show me a drag radial tire for my truck. There is no load or speed rating on those tires.
Old Jun 26, 2005 | 03:50 PM
  #36
Blurry94's Avatar
Blurry94
What size tire are you looking for???
Old Jun 26, 2005 | 04:02 PM
  #37
skipperw's Avatar
skipperw
I would want 275/60/16 for a truck.
Old Jun 26, 2005 | 06:42 PM
  #38
Blurry94's Avatar
Blurry94
With that wheel diameter, your choices are extremely limited. For trucks, the market seems to favor 15" and 18" wheels. I know you mentioned that you don't want to keep swaping wheels/tires, with that said, it may be better to stick with the Toyo's you're currently running...they're good tires.
My stock wheels are 17" and I had no chioce but to get a new set of, custom made, 15" wheels and throw a set of slicks on them. The wheels were only 85 bucks a piece and they have a silver power coating on them. I don't mind swaping back and forth because I want the best traction i can get at the track, and allow my street tires to last as long as possible.
staffcurtis
Feb 19, 2022 12:49 PM
Ford F834
Apr 7, 2012 06:32 AM
401477534
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jan 12, 2012 09:21 PM
frederic
Mar 18, 2008 10:12 PM
