What to do?
Old Jun 10, 2005 | 11:02 PM
wideopen23's Avatar
wideopen23
What to do?
I have a 79 crew cab that I am in need of a/c for. This is my issue. Hot Rod Air seems to have the best system out there, blows the most air and the biggest condensor. Arizona mobile air has a fairly good system as well. Just doest blow as much air and the condensor is smaller. Being my truck is a crew cab I need as much air as possible. The hot rod air is going to run me about 1800 bucks to be installed, the other system is going to run about 1200 installed. Has anyone used either one of these systems? Any help or opions is greatly appreciated.
Thanks
JC
Old Jun 11, 2005 | 09:09 AM
1973F100's Avatar
1973F100
Third option - find a donor truck with factory a/c and swap it over. I did it on my 73 F100; used a 78 donor truck for all parts except compressor mounting brackets and pulleys. Had to get those off a car with same engine as in my truck. Entire job took about three days and cost less than $200. The most difficult part is cutting the hole in the firewall - make a good cardboard template from the donor truck and get out the air chisel. Good luck.
mreilly24
Jul 1, 2011 02:38 AM
TigerDan
Jun 3, 2004 10:25 PM
sarkis
Aerostar
Oct 28, 2003 05:29 PM
Teroy
Jul 8, 2003 09:05 PM
SteveT
Aug 24, 1999 06:38 PM
