Whenever I do some work on anything and a new problem occurs during or immediatly after, always ask myself if something I did is causing it.
In this case since you were working near the dist, coil ,etc. Could you have broken a wire or connection? or possibly replaced a connection to the wrong point?
Bad battery terminal connections? But it wouldn't crank if that was it... There should be power on the solenoid 'S' terminal when the key is turned on. That is the 'key on' power supply for the coil. Check that for power. Might be a bad wire there, or bad solenoid. I've had that happen only once, EVER. Replacing the solenoid fixed it. You can jumber that terminal to 12V for temporary test to see if the engine will start. It just bypasses the key on signal.
Mark
i have same prob with 79 f-250. have replaced ignition module, coil, and distributor. getting no spark from coil, but can see small spark if i remove the Bat wire from coil with ignition on. driving me crazy.
...Welcome roofdr911, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
