Sponsored by: Real Truck
Accessory wiring help
Old Jun 14, 2005 | 10:47 AM
Steve_250's Avatar
Steve_250
Originally Posted by DernMooseAk
The brake light wire and dome light wire in the rear of the bed (underneath) are where the 7 & 4 pin pig tail plug into the trucks wiring harness. I had to replace the trailer plugs on my truck because it was broke. When I went to replace it and found the 2 wires I went back to ford to ask if they knew what they where. Was told they were for brake and dome light for truck toppper.
ARGHH!
I can't find those two wires, where are they?
I found a single green but it is a ground.
I already know that the pin at the one o'clock position in the big plug provides keyed power but I'd rather leave it alone,
Old Jun 26, 2005 | 09:59 PM
Jspafford's Avatar
Jspafford
There should be a 12v wire running back to the 7-way plug. It is used when towing an RV to keep the battery charged and or to run any 12v appliances. Should be a black wire.
Old Jun 26, 2005 | 11:33 PM
BobbyDiesel71's Avatar
BobbyDiesel71
[QUOTE=Steve_250]
Dont the 02's have the open ended 4 wires that are in the engine bay that run into the cab like the 04's have for accessory, ie fog lights?
If you have them they should be on the drivers side next to the hood hinge, inside they end right at the fuse block./QUOTE]
Yes, they do....
Best thing to do in cases where you need power from the battery to accessories at the rear or in the bed is to use one of those wires to connect to a switch inside, then out to a relay in the engine compartment that supplies unkeyed power to the back direct from the battery.
You can visit a boat store (boat US, west marine, etc) and get a good power junction box to hook everything up to. Some are sealed, others aren't, get a sealed one.
You can use the box for anything else you want to wire up.
I would like to see a pic of the 4 wires
I have an 02
EightGodzillas
44
Apr 30, 2016 02:54 PM
bigcountry1009
Dec 25, 2014 07:59 PM
bigcountry1009
Dec 25, 2014 06:18 PM
dittohead
Dec 7, 2014 10:34 PM
mwells
May 20, 2014 10:28 PM
