4-bolt 400
Old Jun 9, 2005 | 10:11 PM
TMI's Avatar
TMI
4-bolt 400
Well, here's a start of a new project. It's a quick picture of a 400 block that we installed 4-bolt steel caps on. The other picture is the stroker piston and rod combination. This combination will yield 434 cubes.
http://www.tmeyerinc.com/images/434block.jpg
http://www.tmeyerinc.com/images/434piston&rod.jpg
Old Jun 11, 2005 | 04:19 PM
titanicf150's Avatar
titanicf150
Tim
Awsome, are those the Kieth Black pistons you were talking about earlier?
Ken
Old Jun 11, 2005 | 06:08 PM
TMI's Avatar
TMI
Yes they are. They come as a forged flat top (zero deck height). We can machine them to acheive up to a 38cc dish. That would get a set of aussie heads down to about 9.5:1 compression ratio. Sounds like we may have at least 3 kits sold and they all might have the CHI heads for them.
Old Jun 11, 2005 | 09:15 PM
mark a.'s Avatar
mark a.
What are you going to do for rods. Why 4 bolts ? are you going to put a blower on it ?
Old Jun 11, 2005 | 10:37 PM
TMI's Avatar
TMI
Honestly, the steel caps are first priority, also nice to have the 4-bolt. With 4.250 stroke, there will be a lot of torque. I bet a very,very close 500# of torque on a really mild application.
Old Jun 13, 2005 | 09:33 PM
good 'ol ford's Avatar
good 'ol ford
ok so how did u do the 4-bolt still a little bit of a new be, did u just machine the other to holes into the block, how much do u plan on selling the kit for cuz im very interested thanx
Old Jun 14, 2005 | 07:48 AM
danlee's Avatar
danlee
Dyno 2K says 513 ft-lbs torque @2000 RPM and 475 ft-lbs@4000 RPM with a Crane #529721 Hydraulic Roller cam. The peak HP is only 380@4500 RPM, but this is a torque motor and should run on 87 Octane with no problem.
Old Jun 15, 2005 | 11:34 AM
78f250_rls's Avatar
78f250_rls
I am very interested in this build, about to start one soon. Any more updates?
Thanks Lee
Old Jun 16, 2005 | 12:33 AM
willd's Avatar
willd
It's about time somebody started doing what should have been done 30 years ago with these motors. From a racing standpoint they have a very desireable ability to have long rods and lots of room for stroke too. If they had just done it right to start with we could have had a 4.155 bore to really compete with the SB chevy crowd.
Now we just need Edelbrock or Weiand to make us a good Stealth or RPM air-gap to feed it. That and a bottom manifold that would allow bolting on the 351W EFI setup on top and we could have factory EFI.
Old Jun 16, 2005 | 06:21 AM
danlee's Avatar
danlee
I am working on an EFI conversion. What I have found so far is an upper intake from a 460 EFI motor can be adapted to a 4 barrel manifold. On the 460 upper, I plan to mount a 2003 Cobra TB. I don't have the 460 upper, yet, so I am not sure about the fit. I have a Lightning MAF and 42# injectors. I will probably buy a manifold and adapter kit from CHI to mate to my CHI heads. I have the fuel rails, a regulator, the injector bungs, a Mustang A9P ECU, and an EFI harness. I also have a 351W TFI dist. I planned to change the gear, but the shaft is cracked.
Does anyone know, if the shaft from a Duraspark dist. is the same as a TFI dist.
Old Jun 16, 2005 | 09:55 AM
78bigbronco's Avatar
78bigbronco
I agree, if the 400's were built like this years ago, by know they would be even more advanced and probably much more supported in the aftermarket scene.
I just got into the 351M/400 motors when I bought my bronc just 4 years ago and just in the time Tim Meyer has really made some strides with the motor. Forged stuff, 4.25 stroke, and even being able to run 'streetable' aussie heads on the above combo.
Danlee... keep me informed on your efi progress. That is one of the things I am going to do for sure. But I was going to go the holley route, with the commander 950 tbi setup. Much simpler comes in one package (everything except the distributor I think). If you can get efi working good using that combination of stuff for less than the holley kit (~$1400) I might be interested. If it does work out good, sounds to me like a tech article in the makings...
Old Jun 16, 2005 | 12:48 PM
danlee's Avatar
danlee
I don't think that my EFI conversion can be done for less than $1400.00. The CHI intake and adapter are almost 1/2 of that, but while the Holley 950 is a Speed Density Bank system, mine will be a Sequential Port Injection MAF system. If someone were to mass produce a kit like this, maybe $1400 would be a target price.
Old Jun 16, 2005 | 08:43 PM
78bigbronco
Yeah, the sequential injection would make it a bit more pricey. But definately should have the potential to better manage the fuel. Your design is probably based around the chi stuff which I wouldnt have so I am not sure if it could work at all anyhow. Still learning about this FI stuff, but I am probably going to get the holley kit for simplicity and that is is decently priced (if there is such a thing).
Old Jun 16, 2005 | 09:01 PM
danlee's Avatar
danlee
The Accel DFI system is supposed to be the best and easiest to tune, but it is still a Speed Density bank fire system. The Holley Commander 950 is as well. The Holley throttle body injection (TBI) is not much better than a carb. Save your money for something better than that.
Old Jun 21, 2005 | 04:20 PM
gow589's Avatar
gow589
Danlee, I have the info in the dyno program and I am showing more:
http://www.rc-tech.net/per/351v400.jpg
I have entered the flow settings for the CHI heads. I am not overly familiar with the program and wondered what I amy be doing different?
Gary
