4-bolt 400
Old Jul 6, 2005 | 09:06 PM
  #46
danlee's Avatar
danlee
I don't have the tables yet. Right now all I have are a bunch of parts. Getting it all to play together will be a good project. I am still trying to solve all the hardware problems. The firmware will come later. Since the MAF is calibrated for 42# injectors, I shouldn't be far off.
You said "Never seen a 90mm injector", Do you mean 90mm Throttle Body?
I checked BBK and couldn't find any 5.0 L TBs over 80mm. Accufab has a 90mm and a 105mm for 5.0/5.8 motors. They were priced pretty high.
Old Jul 6, 2005 | 10:17 PM
  #47
jopey's Avatar
jopey
from what I read those lightning MAF sensors to be used with the stang ECM need to be used with a chip or tweecer. The ECM will not reconize the MAF even thought the MAF was setup with 42 lb injectors.
Old Jul 6, 2005 | 10:24 PM
  #48
jopey's Avatar
jopey
oh I was looking through my emails and accufab said a 75mm would feed a 400 just nicely.
Old Jul 7, 2005 | 07:02 AM
  #49
danlee's Avatar
danlee
At 6500 RPM a 400 will require 752 CFM to fill it's cylinders. But how much pressure drop will occur with a 70 mm, or 75mm or 80mm TB when 752 CFM flows through them. The VE is a measure of the pressure in the cylinder. In a normally aspirated motor, it is 14.7 psi less the pressure drops in the intake and valving. As the motor RPM increases the air velocity increases as well as the pressure drop. The fewer restrictions in the air intake, the greater the manifold pressure and VE at a particular RPM.
EFI unlike a carburator, has no limitation on Venturi velocity at low RPM, so having a larger CFM rating is not as detrimental as with a carburator.
The limitation of EFI is based on Peak Horsepower and the Injector size. My 42 # injectors are sized right for a 540 Peak HP motor. MY TB and manifold will help insure that peak HP is obtainable.
Old Jul 7, 2005 | 12:40 PM
  #50
jopey's Avatar
jopey
I am setting my redline around 5500 or so. not 6500 like your planning, but in saying that your also expecting 100% VE which I am pretty sure all naturally asperated engines can never get that high.
Old Jul 7, 2005 | 02:04 PM
  #51
danlee's Avatar
danlee
Naturally aspirated motors can exceed 100% VE at very high RPMs. This can be the result of Ram air or intake tuning. I don't expect to get any intake tuning, but maybe some ram air effects. Look at EFI systems on late model EFI V8s, and see the length of the runners. These long runners provide tuning to increase the VE at mid-range RPM.
My aim is to get the VE as high as possible.
Jopey,
I have a question that you may be able to answer. The stock 5.0 Mustang Oxygen sensor is a three wire device. Is this a Narrow Band Oxygen Sensor or a Wide Band. Do I need a four wire sensor for Wide Band. I know that a Wide Band oxygen sensor will make tuning easier. can I use a Wide Band Sensor with an A9P ECU?
Old Jul 7, 2005 | 05:28 PM
  #52
jopey's Avatar
jopey
I do beleive the stock O2's are narrow band. I do not know if a wide band O2 is even capitable with the stang ECM. Head over to corral.net some of those stang guys are very well educated on 87-93 MAF stangs.
If you want the tables for the 90mm MAF lightning for your tweecer let me know I got them from tweecers forums.
Old Jul 7, 2005 | 06:33 PM
  #53
danlee's Avatar
danlee
Jopey,
I don't have a tweecer yet, so the tables won't do me any good. There is someone in a Yahoo group that I suscribe to, who is working on a boot loader to burn into EPROM. With this boot loader you will be able to load tables into EPROM and have them loaded into program space at startup. This will elimnate the need for a Tweecer. I will follow his progress.
I ordered a Cold Air Kit for a Lightning from BBK today. It won't fit my application exactly, but I am getting some flex tubing along with it. It will require some fitting. I bought it from the BBK website. It was listed as used/return/test. There are some decent buys on that site.
Old Jul 7, 2005 | 08:13 PM
  #54
jopey's Avatar
jopey
It will be interesting to see if he gets that running like that. I know I am going to get the tweecer RT right from the start. you can get them used on corral fairly often for decent prices.
Old Mar 26, 2006 | 07:57 PM
  #55
gow589's Avatar
gow589
Originally Posted by danlee
Dyno 2K says 513 ft-lbs torque @2000 RPM and 475 ft-lbs@4000 RPM with a Crane #529721 Hydraulic Roller cam. The peak HP is only 380@4500 RPM, but this is a torque motor and should run on 87 Octane with no problem.
I thought it would be neet to bring back the original thread where we started talking about the dyno numbers for this engine. It made a bit more then 380 hp though.
Good to see the actual results.
Gary
Old Mar 26, 2006 | 08:23 PM
  #56
danlee's Avatar
danlee
Gary
Gary,
That was an early run on DD2K with 9.0:1 CR, and a 600 CFM carb. The later simulation was on Dyno Sim using 10.5:1 CR, and 800 CFM carb and large tube headers. This gave results that are closer to actual. I have seen on several occasions where actual dyno results beat the simulation. Maybe we will see that again.
Old Mar 28, 2006 | 11:44 PM
  #57
roger dowty's Avatar
roger dowty
a guy has some 4 bolt steel caps that are advertised for both 351W, and the 400. Does this sound right?
Old Mar 29, 2006 | 09:13 AM
  #58
PWRPROD's Avatar
PWRPROD
Pwrprod
Roger : The 4 bolt mains caps are an after market item to strengthen the bottom of the 351M/ 400 engine. They definatly work and do need a machiene shop to drill and tap the extra bolt holes. I wish I had known of these when I rebuilt my 400. This will let you pump the ponies past the 400 level on these engines and keep the bottom together.
Old Mar 29, 2006 | 12:50 PM
  #59
danlee's Avatar
danlee
I believe that the mains are the same for a 351W and 400. I do not know if the main caps are interchangeable.
Old Mar 29, 2006 | 11:09 PM
  #60
Brian S's Avatar
Brian S
The mains are the same size but the caps are not interchangeable. A 351W and the 351C/400 bolts are not spaced the same distance apart. For what it's worth, Shazam elongated the holes on a 351W main stud girdle and used it on a 400 stroker that held 800 HP.
TMI
Feb 16, 2016 06:47 PM
TMI
Jan 10, 2015 01:44 PM
TMI
Jul 6, 2014 09:21 AM
TMI
21
Mar 29, 2014 10:19 PM
TMI
Nov 4, 2004 03:50 PM
