Engine Weights...
Old Feb 21, 2014 | 09:50 PM
TMI's Avatar
TMI
Engine Weights...
How much does a 351C NASCAR block from Australia weigh?
Which is lighter a 351C or 351W?
How much does a 351C short block weigh?
Click here and find out and more. We've added many pictures of different engine weights.
Engine weights | Pinterest
Old Feb 21, 2014 | 10:33 PM
Cole Neese's Avatar
Cole Neese
I'll take ~30 more pounds for 50 more cubes. 400s are awesome it is interesting to see the comparison though. I'm guessing adding the main caps to the 400 would add another 5-6 pounds? I don't see one on there with them.
Old Feb 22, 2014 | 11:14 AM
TMI's Avatar
TMI
Weights for the Tod Buttermore 9.200 & 9.350" version have been added.
Old Feb 22, 2014 | 07:45 PM
Gary Lewis's Avatar
Gary Lewis
Tim - How much less is my 400 going to weigh w/the Trick Flow heads? You have "400 Ford complete engine, cast iron heads, aluminum water pump. #530".
Old Feb 24, 2014 | 12:23 AM
smokenchoken's Avatar
smokenchoken
IIRC a 390 with aluminum heads and intake weighs less than the 351w and way out performs it would love to see all the actual numbers.... FE is rags to riches and every point in between
Old Jan 10, 2015 | 01:44 PM
kopfenjager's Avatar
kopfenjager
Same question, what does an alloy headed 400 weigh with alloy manifold and water pump? I imagine somewhere around 440-450lbs?
MattMac
Apr 29, 2017 12:12 AM
BigBadFord80
Jul 27, 2004 05:22 AM
jwtaylor
Dec 24, 2003 05:56 PM
slmd350
Nov 5, 2003 04:57 PM
mositso
21
Oct 6, 2003 03:47 AM
