using used oil
Old Apr 23, 2007 | 05:08 PM
  #31
fixnair's Avatar
fixnair
I'm sorry. Shalome is about all the hebrew I know.
Old Apr 23, 2007 | 05:32 PM
  #32
biga17133's Avatar
biga17133
Originally Posted by MARYLAND SMIB
You mean JP-5/8 is jett fuel, JP-4 is fuel oil. used for ships to burn. JP-5 is rough running on the engine than Diesel, it will work but has been known to run rougher.
I use red diesel in my tractor, seems alright I use seafoam every couple of tanks to keep her going right.
You the first one i seen that uses seafoam i just started useing it (1) can so far in my 4x4 a old old ford man told me it is the best and i could even use it in my lawnmower glad to see that some one else has now i feel better about doing it..lol
Old Apr 23, 2007 | 06:36 PM
  #33
vjan1_2000's Avatar
vjan1_2000
what does sea foam do?
Old Apr 23, 2007 | 08:37 PM
  #34
harleyjohn45's Avatar
harleyjohn45
carb and injector cleaner, almost as good as lucas injector cleaner. i have not been adding any 2 stroke oil up to this point, just a little lucas and diesel kleen. with the new low sulphur fuel, i will start adding at least 1 ounce of 2 stroke oil for each gallon of diesel.
hrdrckgld
Aug 14, 2014 10:49 PM
FordOwnerJoey
Mar 31, 2013 05:32 PM
derek0525
13
Oct 20, 2011 06:59 AM
Knotwild
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 14, 2009 03:03 AM
jgc2521
Aug 21, 2008 09:03 PM
