I'm doing a Mass Air conversion on my F350/E4OD, I need to know what computer would be the best to use? the lightning, or the standard '94/95-5.0/5.8? mind you i am running a 427W stroker now... with a 272H crane cam, trick flow intake and world heads.
The lightning mass air computer was never installed in anything from the factory to my knowledge, so I suppose that makes sense why you can't find it. Have you asked around on the lightning forums www.nloc.net ?
'93 lightnings were SD, '94 were SD, and i believe a few later ones,(Calif. models) were MA, '95 they were all mass air. from what i've read. thanks for the site, i'll try it.
Talk to Blurry94 on this board, he is also on NLOC and could probably help you out. I don't think any of the first generation lightnings were mass air from the factory. The part number for the lightning mass air computer that fordfuelinjection.com lists is a '98 part number.
