need help rusty 89 ford f150
Old Jun 8, 2005 | 09:20 PM
JohnBmrq's Avatar
JohnBmrq
Question need help rusty 89 ford f150
i have a 1989 for f150 ext. cab, the floor is prety well rusted out, and i have some rust on fenders an such... will a stnd. cab fit on my truck w/a long box, or should i just try to repair the rust and rust proof the underbody? along w/herculine the inside of the cab, i do not plan on putting carpet back in there, with how often i am in the woods it ggets wet and stays wet too long. also what body part years will fit an 89 f150? fenders and floors, rocker pannels, and so on..?? also what should i do about fender flares? bushwacker are too expencive for me at this present time? is there anything else that contours with the body?
Old Jun 9, 2005 | 07:21 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 10, 2005 | 07:05 PM
kenseth17's Avatar
kenseth17
body parts from 1987-1991 will fit. I am not sure on the swap. There are 5 different frames for 87-91. 116" wheel base, 133",138",155" and 168". Should you repair it, depends on how much skill you have, if you have access to the tools needed, and how much time you have and how much you have to invest. Bodywork is very time consuming. I am not sure of where you could get flares, someone else may come along with an idea. Or if you end up doing all the bodywork, you could pick up some foam, and cut and form it to make the shape of the flares, and lay up some layers of fiberglass mat and resin and then do some grinding,sanding and bodyfilling and priming on them to get them ready for paint. Its really up to you to decide what you want to invest both time and money, and if you think you can pull it off. Bodywork isn't overly difficult, but takes lots of time and patience to get it right and material costs can add up quickly. Also to much heat buildup welding can warp sheetmetal in a hurry. There are a quite a few places that sell rust repair panels, Browns of two rivers sell them around here, also can check mill supply even jc whitney. I am not sure of who deals mainly with f150s, but someplace like that maybe would carry them too. Might have to do a search for rust repair panels.
Old Jun 12, 2005 | 10:39 AM
JohnBmrq's Avatar
JohnBmrq
fenders will also fit into 87-91? i think i am going to just try to find anothercab to roll onto the frame, i dont have much body experience... i'll have to just save my pennies... thanks for the info, with the frame diff's... will that affect the cab sizes? thanks again...
john
Old Jun 12, 2005 | 02:10 PM
kenseth17's Avatar
kenseth17
yes fenders are listed the same for 87-91. I don't know on the cab sizes, but may have different body may have different body mounting points and the length of an extended cab is going to be larger then a standard cab. I don't know the answer to that question for sure, I never tried it.
southern-old-bold
Jun 11, 2016 05:58 PM
cruisetopdown
Oct 17, 2013 01:58 PM
oldmongo
Apr 19, 2012 02:57 PM
jk89cat
108
Mar 15, 2012 09:16 AM
Jim_Philly
Aug 31, 2011 10:36 AM
