Aerostar Ford Aerostar
Desperate please help
Old Jun 8, 2005 | 10:42 AM
momsvan's Avatar
momsvan
Question Desperate please help
I have a 91 Areostar that started going dead when idling but after you got over 35 mph, it ran fine. Then it got harder to keep it running long enough to get to 35 but seemed to do better when warm. But would shudder and try to die at stop signs. Then it would bog down, shudder, and backfire when taking off but do fine over 35. Now it will start but is hard to keep running long. The actions i have taken are as follows. Changed spark plugs and wires,distributor cap, oil,air and fuel filters,cleaned throttle body and egr valve. Please help. I am desperate as this is my family's only tranportation.
Old Jun 8, 2005 | 12:29 PM
Torsen Rick's Avatar
Torsen Rick
Any chance that the cat is plugged?
Old Jun 8, 2005 | 12:41 PM
copper_90680's Avatar
copper_90680
I can only think of two things:
IAC or unreleased locked up Torque Converter.
To eliminate the Torque Converter, shift to Neutral at the stop light. If it still wants to die, then it's something else.
To check the IAC, warm up the car and unplug the IAC. If the engine runs really rough or dies when you do that, the IAC is probably OK.
Also, did you get any code? When was the last time you replaced your O2 sensor? If you have never done that, then I'm afraid Torsen Rick is right and your cat is probably plugged up. My stupid brother did that to his Explorer. He was trying to save $50 on the cost of a new O2 sensor, now he's paying hundreds for a new cat, not to mention all the money wasted because of the 13mpg mileage. Real smart
Old Jun 8, 2005 | 01:20 PM
krankshaft's Avatar
krankshaft
Speaking of that how often should you replace your 02 sensor? My 96 is on the original one and its at 47k miles.
Old Jun 8, 2005 | 01:22 PM
copper_90680
My original O2 sensor went at about 60K, so I replace them at 60K regardless of whether I get a code.
Old Jun 8, 2005 | 01:27 PM
krankshaft's Avatar
krankshaft
Well then in a couple of thousand miles I'll be replacing mine then I don't want to plug my Aeros 2 cats double the trouble .
Well this is odd I just looked on Autozones site for the location I know its screwed into the exhaust pipe but was just checking but it says theres one before and after the cat?
Now I know why its expensive to replace theres two of them.
Old Jun 8, 2005 | 02:14 PM
asavage's Avatar
asavage
FTE Community Team
Cat plugged: not likely, as the symptom of a plugged cat are *worsened* as you rev it up. By the time the cat is plugged enough to make idling rough, it won't run fast enough to get out of its own way.
IAC: won't produce a shudder or backfire symptom no matter how it fails.
Normally I'd suggest the plugs & wires, but you've already covered that.
If it's a 4.0l, Ford MAFs fail with those symptoms. Harder to check though, and expensive to replace. I've seen at least one 4.0l in a '94 Explorer that ran like that with a failed MAF and it didn't code!
If you can borrow one, I'd probably run a fuel pressure check first. My '89's fuel pump failed with low pressure and wouldn't idle when it warmed up.
Old Jun 9, 2005 | 10:39 AM
momsvan's Avatar
momsvan
thanks guys. i am in the process of having all these things checked out. you all have been VERY helpful seeing as how none of the mechanics i have talked to have had any idea what the problem is. one has suggested the head gasket blown. does this make sense?
Old Jun 10, 2005 | 01:57 AM
rlmdad's Avatar
rlmdad
From your description it sounds more to me like the IAC might be dirty or bad. Is it hard to start? What plugs did you use when you replaced them? These Aerostars can be quite fussy on the brand of plugs used.
I doubt that you have a blown head gasket as you did not mention anything about loss of coolant or oil and no mention of exhaust smoke, both of which you would more than likely see with a blown gasket.
Just my 2cents
Ron
Old Jun 10, 2005 | 02:04 AM
kermit's Avatar
kermit
maybe a vacuum leak somewhere, i had very similar symptoms on my 96 windstar and found a big vacuum leak, fixed it and havent had a problem since.
Old Jun 10, 2005 | 02:12 AM
rlmdad's Avatar
rlmdad
Kermit's right, a vacuum leak could cause these same symptoms and replacing a little hose is much easier and cheaper than anything else. So check your vacuum lines from the vacuum tee out to the actuators.
Another thing to check would be the fuel pressure regulator. Sometimes the diaphram develops a leak and can allow fuel to be sucked into the engine through the vacuum line. A quick check would be to check your oil for a fuel smell or remove the vacuum line from the fuel pressure regulator and check it to see if it has a fuel odor or fuel. My 3.0L's regulator went bad and I had to replace it, the oil and oil filter due to this fuel contamination.
Ron
Old Jun 22, 2005 | 12:31 PM
momsvan's Avatar
momsvan
Hey Guys. Wanted To Get Back To You All And Let You Know The Problem Was A Map Sensor And Water Pump Had Locked Up Also. You All Were Very Helpful. Thank You So Much. I Am Happy To Be Back On The Road Again. Thanks Again!
Old Jun 22, 2005 | 03:24 PM
aerocolorado's Avatar
aerocolorado
Glad you're back in action. One question, was it the MAP or the MAF sensor that was bad? My pickled, pea brain seems to recall that the MAP sensor in '91 was not a true active input sensor but acted rather indirectly as a barometric sensor for altitude compensation. On the other hand, I can also see if the MAP were sending a false positive signal the ECM would produce an incorrect fuel/air mixture with driveability problems. Just curious.
ZRNation
1997 - 2003 F150
Jan 15, 2013 11:58 AM
barthel
Modular V10 (6.8l)
Apr 23, 2011 11:36 PM
otrawj
Apr 10, 2011 03:47 PM
szealuss
Oct 17, 2010 10:48 AM
motometal04F350
May 19, 2009 12:29 AM
