Modular V10 (6.8l)
Need help diagnosing a "Misfire"
Old Apr 17, 2011 | 10:27 PM
barthel's Avatar
barthel
Hey Guys,
Well, I towed with my truck for the first time this weekend, but I'll save that for another thread.
Right after I bought the truck (about a month ago), I did a tune up on it, plugs, new boots, etc. Soon after that, it started idling rough and the SES came on, P0307 misfire #7 cylinder. I swapped #6&7 COP's to see if #7 was bad, problem cleared up and the truck ran like a top.
Truck ran fine on the way out, fine while out there (California desert) but when we left it started idling rough, the SES came on, same code, #7 misfire. I lifted the hood, wobbled the COP, started it again and it seemed fine. Started to drive back, it started shuddering and hesitating, no SES but when I pulled over I plugged in my code scanner and got P0300 Random Misfire. I swapped 6&7 back and went on my way.
Well, the idle seemed OK, but would get rough occasionally. The truck seemed to run fine, but I noticed with lower RPM's (under 2100) the truck would shudder if I gave it gas. If I downshifted and got the RPM's up, it ran great.
So, the question in this long winded post (sorry) is do I start with he COP's and work my way backwards? Replace 6&7? It now keeps throwing the "random" misfire rather than #7 misfire.
Thanks in advance for the help.
Old Apr 17, 2011 | 11:01 PM
jh818's Avatar
jh818
I wonder if it's your injector?
Old Apr 17, 2011 | 11:26 PM
barthel's Avatar
barthel
Thought about that, but wouldn't I get a "lean" code as well if it was an injector?
(Not sure, asking) =)
Old Apr 18, 2011 | 11:36 AM
jh818's Avatar
jh818
Not sure if you would get a code.
Old Apr 18, 2011 | 04:35 PM
andrewzx92000's Avatar
andrewzx92000
I have a bad injector and with 2 bottles of gumout from walmart it clears up, but it has not ever thrown a code or check engine light, its really frustrating because its not quite bad enough for me to work out which one it is, it won't miss consistently.
Gumout is cheap, 2 bottles and 20 miles mine usually comes right.
Andrew.
Old Apr 18, 2011 | 07:40 PM
Wolfboro's Avatar
Wolfboro
You may want to double check #7 COP harness to make sure you have a good contact .
Good luck.
Ken
Old Apr 18, 2011 | 10:43 PM
barthel's Avatar
barthel
Update:
Well, It's still running like crap. I hooked it up to the scanner again today, it still shows the "P0300" code, but shows a "pending" code for misfire on #7.
I'm of the mind that there's some sort of issue with #7, gonna start by replacing the COP and see if that clears the issue, I'll move to the injector from there. Anyone have any other suggestions?
Old Apr 18, 2011 | 11:16 PM
jh818's Avatar
jh818
Pull the plug also to make sure there's nothing wrong with it. New plug could be defective.
Old Apr 19, 2011 | 03:46 AM
p-nut's Avatar
p-nut
I have seen plenty of off-the-shelf bad plugs in the past few years. The resistor that is in the plug isn't what it used to be anymore. Change that single plug, replace the plug boot and try again.
If it turns out to be an injector, they can be had on ebay brand new for under $20.
Old Apr 19, 2011 | 07:45 AM
JWA's Avatar
JWA
Good luck.
Ken
I had this exact same issue on my '00 5.4 gasser----drove me nuts looking for a bad part when all along it was a damaged #7 connector. Quick trip to NAPA for their part number EC259 ($20 ea), one helluva time splicing it into the harness (E250 van) and all has been good since.
Seems the locking tabs are easily damaged when changing plugs/COP's or they break due age-----either way just one more thing to test and check.
Old Apr 19, 2011 | 09:40 AM
barthel's Avatar
barthel
Thanks guys, I'll start by changing the plug (just happen to have a spare set) and go from there.
I'll report back and let everyone know how it goes.
Old Apr 19, 2011 | 08:14 PM
barthel's Avatar
barthel
Update 2:
Well, I pulled #7 plug. It didn't look too bad, but maybe worse than i thought it should after 700 miles. Cleaned the COP & connectors, cleaned the injector connectors, put everything back together. Started it up, no sputter or anything like that. Took it for a drive around the block, it ran like a top, smooth idle, sounded great.
No SES light, but it still shows a pending code for #7 misfire, will that clear up over time or should I just clear the DTC's?
Not ready to cry victory yet, but things are looking better than they were yesterday!!
Old Apr 19, 2011 | 09:31 PM
jh818's Avatar
jh818
I would clear the codes and see.
Old Apr 20, 2011 | 04:28 AM
JWA's Avatar
JWA
+1
If you think you've fixed the condtion then clearing the code is the only way to know if the ECM agrees!
Of course if you effected the repair after 10 times of starting the engine without a code the existing one will clear itself. In the end its easier to clear it yourself and see what happens.
Old Apr 23, 2011 | 11:36 PM
barthel's Avatar
barthel
Another update: (and hopefully the last on this issue)
Well, cleared the codes and finally got to drive it today. Just drove around town and ran a few errands, truck seemed to run fine. Checked for new codes twice during the drive and when I got home, no codes.
Seems to have taken care of the problem at least for now.
Thanks for all your help guys.
daveplot
Jun 20, 2022 11:13 AM
BrentD22
1997 - 2003 F150
Jan 27, 2017 12:07 AM
ItsAndy
Mar 18, 2016 04:26 PM
Stevil
3.8 & 4.2L V6
May 2, 2012 06:55 AM
ChaosClown
1997 - 2003 F150
65
Nov 14, 2011 06:06 PM
