Holset H2E
Old Jun 7, 2005 | 10:36 AM
merc460's Avatar
merc460
Holset H2E
I just picked up a Holset H2E for my 460 turbo project. Before I spend any money on this turbo I am wondering if any one could tell me how compatible this unit will be. I plan on making 10 psi of boost no more, redline will be 5500 to 6000 rpm and running on Propane. The current combination is a .060 over block with forged dished pistons cj rods and a stud girdle. I plan on using D3 heads with a home port job and a cam yet to be determined. I have searched on this turbo I know it can flow 1000 cfms this is about 200 more than my combo calcutates out at. I guess my question is will this turbo make the boost I want at 2000 rpm or 4500 rpm? If boost starts to late I may switch to a smaller HX 35 found on the dodge Cummins diesel. Any input will be appreciated.
Old Jun 25, 2005 | 10:07 AM
F150daniel's Avatar
F150daniel
http://www.turbomustangs.com/forums/...ght=Holset+H2E
http://www.turbomustangs.com/forums/...ht=Holset+HX35
Old Jul 23, 2005 | 04:37 PM
brown79's Avatar
brown79
what are you using for (A) propane mixer(s) ?
Old Jul 23, 2005 | 09:21 PM
merc460's Avatar
merc460
I am going to use a Technocarb 750 CFM with a Model F Vialle convertor . If one convertor is not enough the technocarb has provisions for two convertors
Old Jul 24, 2005 | 07:36 PM
brown79's Avatar
brown79
cool let me know how the technocarb works. is that a dual mixer adaptor for a single 4 bbl manifold i saw in your gallery?
the reason i ask is because i have a propane 460 in my 79 i have one impco 425 on a stock intake.
Old Jul 25, 2005 | 12:16 AM
merc460's Avatar
merc460
It is a single mixer the dual mixer Idea never got off the ground There where big time hood clearence issues even with the hole I cut in the hood, and in the end the two mixers would still draw through a single four barrel throttle plate.
Old Jul 25, 2005 | 04:34 AM
Scopie's Avatar
Scopie
you looking at a blow through or suck through setup?
I am almost finished with an eaton M112 supercharged 351c on propane using dual GRA mixers form http://www.gasresearch.com.au/ they sell a convertor with 2 x 90' inlets for 2 mixers, which might help ( http://www.gasresearch.com.au/g001.jpg )
Old Jul 26, 2005 | 01:48 AM
merc460's Avatar
merc460
I plan on going blow through. I already have all the propane stuff I need but that is a cool site. one advantage of the technocarb mixer is no diaphrams that can fail under boost like on the Impco mixer.
Old Jul 26, 2005 | 09:06 PM
brown79's Avatar
brown79
what does the technocarb setup cost? it looks like it would wake my ol 460 up compared to my singe impco 425. do you have to modify the mixer before feeding it the boost?
Old Jul 27, 2005 | 10:17 AM
merc460's Avatar
merc460
As far as I know you do'nt have to modify the mixer i geuss I will find out . I traded my complete new dual mixer impco set up for this technocarb and regulator. there is a fellow in my provence that sells them, he has a web site http://www.propaneguy.com/
Old Jul 27, 2005 | 10:56 PM
brown79's Avatar
brown79
thanks for the link i saw that sight months ago and havn't been able to find it again since i think i might have to get one of those!
powerdog
4 Cylinder Engines
94
Jul 26, 2021 12:11 AM
HANDSOME
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Oct 18, 2015 12:04 AM
oldblue89
20
Nov 28, 2012 05:13 PM
boggerted
Mar 9, 2012 07:11 PM
swooshcmk
23
Nov 21, 2010 07:56 PM
