ats uprgrade 093 vs 12cm holset hx35
Which turbo would run better on the idi? An aftermarket ats 093 upgrade turbo (3 inch downpipe and larger exhaust housing I believe) or a wastegated hx35 with the 12cm exhaust housing? I can get a good used a holset from a 2000 dodge cummins about $200, how do these turbos compare to eachother? How do the sizes compare? The plan would be a stock pump turned all the way up, intercooled and no more than 20psi boost. Lots of low rpm power with quick spool would be best, for towing and fuel efficiency. Anyone have any recommendations for a turbo that would be an improvement over the ats? I might use the ats pipes or build a custom setup.
Thanks
Thanks
I have the hx35 12cm on mine and i like it. It is noticably bigger than the 088 ATS turbo as well as the old Banks. But i dont see why you couldnt use the up-pipes from another kit, even if it does take a little doing. Might have to make an adapter to change the angle or something, but shouldnt be too much work. I built my up-pipe using the factory NA Y-pipe.
Do you have an idea of any chargers that would meet these goals better?
Thanks
I am new to this thread. I am very interested in the upgrade you are referring to above. I just purchased a 1994 F350 4X4 7.3 IDI & E40D transmission. We just finished our maiden voyage with a 20' travel trailer in tow est 5,000 lbs loaded & had a bit more trouble in the long hill sections going to a lake we frequent.
Please let me know what you would reccommend for towing & mpg.
My ideas are intercooler new or fabbed 3"dp & possibly a Snow injection kit & to keep track of egt's.
Any & all the help/guidance you can provide would be greatly appreciated.
John
John
Personally i doubt you would need the snow kit, and for the price im not very impressed. IC definately, 3" DP definately. Check out R&D IDI Performance for the turbo / fuel upgrades.
Go to his site and contact him about the turbo. I don't see the turbos on it but he should be able to help you out there. Also as far as water/methanol goes, there are cheaper kits than the Snow Performance kits but they are really good for lowering egts when towing. Plus it provides a nice power upgrade as well.
