General Automotive Discussion
Need help with 351 Arca car
Old Jun 6, 2005 | 09:50 PM
rangersvt04's Avatar
rangersvt04
I have a circle track arca series car that has to be converted to cast iron exhaust manifolds.
we are running a 351W with the ford racing M-6049-N351 sportsman heads . The problem is we cant get the manifolds to mate to the heads. the heads have bigger ports and use a wide bolt pattern. I pulled a adaptor plate part number from ford racing04 catolog. Went to order the part to day and ford dosent make the adapter kit any more. so does any one know ware i can find this part(i will post part no. later i cant find it )
Old Jun 7, 2005 | 09:56 AM
Roushians's Avatar
Roushians
ARCA car, as in ARCA stock car racing?!
Old Jun 7, 2005 | 04:33 PM
rangersvt04
yes as in ARCA
Old Jun 7, 2005 | 09:44 PM
Purple55's Avatar
Purple55
I would check with your local engine builders.I can't remember any in your area,but the ones I used to use in WI. are Wagner Automotive in Markesan,B & B Racing in Appleton,and Schleipers in Milwaukee.They might have something "laying" around or know someone who does.
I may be able to run the part # on a locator for you also.
Old Jun 10, 2005 | 09:47 PM
Grandpa's1983's Avatar
Grandpa's1983
Purple55, let me try to connect the dots....
your last name is Holzhausen,
you have car #87,
you know machine shops in Wisconsin,
that means
You must be related to Steve Holzhausen #78
oh yeah, you said run a part # on locator, work at a dealership?
I will either be right or sound pretty stupid, either way it wont be the first time.
Lewie
Old Jun 11, 2005 | 08:36 AM
Purple55's Avatar
Purple55
you have car #87,
that means
Lewie
Correct!
Old Jun 11, 2005 | 08:44 AM
Racerguy's Avatar
Racerguy
Do you think the N351 heads will work ok with the stock manifolds?
What does everyone else run? Besides Chevs
I used to have to run stock manifolds and I used GT40P heads with good success.
Old Jun 11, 2005 | 09:25 PM
rangersvt04
well the sportsman series wont allow gt-40 heads. but the sportsman/street stock will allow the svo heads.
its looking like we found a set of svo heads and manifolds.
ola1234
Nov 23, 2016 09:01 PM
craveman85
Feb 19, 2016 07:05 AM
STGFordCrazy04
South Carolina Chapter
May 7, 2008 06:42 AM
Chickenbone
Apr 9, 2008 08:30 AM
Matts72
Engine Swaps
84
Aug 17, 2006 12:57 PM
