filter relocation kit for 99 XP?
Old Jun 6, 2005 | 06:38 PM
orleec's Avatar
orleec
Is there a filter (engine oil filter) relocation kit available for 99 Expedition, or any 1st Gen XP for that matter?
Old Jun 7, 2005 | 03:49 PM
n2umr's Avatar
n2umr
The oil filter on my 99 XLT Expy is located right behind the drivers side headlamp in front of the wheel. Real easy to change.
Mark
Old Jun 7, 2005 | 05:38 PM
orleec's Avatar
orleec
Any Negative Feedback On Relocated Oil Filter???
I thought relocating it would make it even easier. Had the pleasure of changing my XP-oil and I got to say its not as easy as my wife's V70 - one cannot avoid to get 'oiled'.
I'm up for another oil change and I thought the time to do it is now.
I found http://store.summitracing.com part no. TRD-1227 which got double filter (TRD-1127 is single filter).
Any thoughts, comments, bad experience on trying remote oil filter?
Thanks
Old Jun 7, 2005 | 09:17 PM
ford390gashog's Avatar
ford390gashog
well the bad side is you can cause extreme startup wear because it take longer to get oil up to the valve train and whats the big deal with where the filter is now seems pretty easy to me i have never had a problem with it. sure you may spill some oil but oh well.its a oil change.
Old Jun 9, 2005 | 06:29 AM
BigDASH's Avatar
BigDASH
Do you have small hands? Because I have big hands and I have a hard time getting the oil filter wrench up to the filter to get it off. Relocation is GOING to happen on my truck... Now all I have to do is save up my pennies
Old Jun 9, 2005 | 08:05 PM
ford390gashog
small hands , nope about 6 inches wide 8 inches long i have the biggest hands i have ever seen but i never use a filter wrench to remove it i use my hand if you put it on right it won't be to tough to get it off you just allow the gasket to contact the mounting surface then turn 3/4 turn then you're done.
Old Jun 9, 2005 | 09:41 PM
bigCraig's Avatar
bigCraig
I weigh 375 and have never had a problem r/r filter or drain plug on my 98 4x2 5.4, i dont even have to jack it up.
Old Jun 10, 2005 | 11:59 AM
hceptj's Avatar
hceptj
I was just looking into one for myself. My '99 4x4 makes a mess when the filter is changed due to the location. I found a kit at performancecenter.com for about $60.
Hope that helps...
Old Jun 10, 2005 | 09:20 PM
orleec's Avatar
orleec
Thanks. I'll check it out.
fyi, I also found one http://store.summitracing.com part no. TRD-1227
I'm hoping to find one that is not universal and will use the oil filter that first generation expediton uses.
Haven't heard from anybody who had tried one on their expedition and should be interesting to hear form them first hand if it its worth it and if it in fact cause their motor to go bad pre-maturely.
Old Jun 12, 2005 | 04:40 PM
pounder90's Avatar
pounder90
I bought the Perma Cool filter relocation kit from Summit for my '00. I have not installed it yet. I assembled it and have it ready to go in. It seems like a high quality kit. Just waiting for the next oil change to come due. The kit p/n I have is PRM-10695. I will post an update once its installed in the next couple of weeks.
Old Jun 13, 2005 | 04:40 AM
orleec's Avatar
orleec
Will it be using oil filter for expedition?
Old Jun 13, 2005 | 11:13 AM
BigDASH's Avatar
BigDASH
Do you have the 4x4? On the 4x4 the transfer case is ALL in the way. In order to get the filter out you have to reach between a crossmember and the transfer case to get it out BLINDLY. All those with 4x4 will agree that the filter removal is a BEAR!
Old Jun 13, 2005 | 04:15 PM
pounder90's Avatar
pounder90
The Summit kit uses Ford type filters, like the FL1A. It is actually a larger filter allowing for more capacity.
Old Jun 13, 2005 | 05:10 PM
Darth Baiter's Avatar
Darth Baiter
Are we all talking apples to apples here? I have a 4.6L 4X4 - The oil filter is located right behind the drivers side headlamp in front of the wheel. Real easy to change. Yeh it takes one hand to unscrew the filter once it's loose and the other hand holds a small drip tray to catch the mess from the filter. It's a juggling act to minimize the mess but access is cake. I see most of the complaints from from 5.4L owners. I new there was another reason for buying the 4.6L besides the dream of good gas mileage with sufficient power. Haven't realized either of those, but oil changes are easy.
Gibby55
Aug 29, 2012 12:41 PM
FX4DaDtoplay
Aftermarket Products
Feb 26, 2011 09:12 PM
bktoney
1997 - 2003 F150
16
Jan 13, 2004 01:24 PM
MisterCMK
Oil & Lubrication
Jul 30, 2003 08:15 AM
6 cyl boy
16
Feb 7, 2003 08:06 AM
