sonnex kit
Old Jun 7, 2005 | 06:09 PM
Skeeter2221's Avatar
Skeeter2221
I've search google with no luck. Where did you all get the sonnax kit. blackcloud.com isn't a tranny site.
Old Jun 7, 2005 | 06:18 PM
fast freddie's Avatar
fast freddie
Might want to check ebay. Seems like I have seen them there for around $50.
Old Jun 7, 2005 | 07:16 PM
SpringerPop's Avatar
SpringerPop
Johnny8,
No, actually, the normal fluid level is below the lip of the pan, so if you were able to take the pan down completely level, you wouldn't even have to drain it first. If the pan has a drain plug, just open it first. If not, you could use the pump, but it's not really necessary.
Put a plastic tarp down before you start this project. It helps with the cleanup, and it also helps keep dirt and sand out of the area where you are working, thus keeping down the chance that dirt would get onto any tranny parts while they're down.
Skeeter,
Dieselinnovations.com has them.
Pop
Old Jun 7, 2005 | 07:22 PM
johnny8's Avatar
johnny8
Originally Posted by SpringerPop
Johnny8,
Pop
i was reading this post that i have on changing the fluid and it talks about unhooking the line at the tranny cooler then starting the engine to pump most of the fluid out of the tranny... then you filler back up with the new fluid... i just thought that if most of the fluid was pumped out you could easilly do this sonax upgrade without having to worry about spilling a bunch of fluid... or any at all for that matter... then just fill her up like you would have to do anyway... am i missing it on this one..?
Old Jun 7, 2005 | 07:26 PM
SpringerPop
I suppose you could do that, but if you inadvertantly let it run too long, you may find yourself running the tranny parts without any lubrication, a no-no. I prefer not to let hydraulic systems run without fluid. Bad things sometimes happen.
Pop
Old Jun 7, 2005 | 07:30 PM
johnny8's Avatar
johnny8
yes... the article mentioned that ... the reccomendation was to has someone maning the key so as soon as you saw the fluid flow cutting out you could instantly shut her down... now.. my plan was to determine the total amount of fluid in the tranny and the torque converter and get a container that would hold a few pints LESS than that and just fill it then shut off the engine... that would get most of the fluid out and that would be better than nothing... any comments on my idea...?
Old Jun 7, 2005 | 11:20 PM
SpringerPop
There are only about four or five quarts in the pan. Once the front pump has pretty-well sucked all the fluid out of the pan, and the pump runs dry, there won't be any oil pressure to continue to push the rest of the fluid out of the cooler lines.
As an aside, some folks believe that, at this stage, they can get an effective complete oil change by beginning to dump fresh fluid in the pan. This WILL continue to force out old fluid (somewhat mixed with the new), but that doesn't get the pan emptied, and that was the original point, wasn't it?
If you HAVE to drain the pan this way, just shut it down immediately when the fluid stops. Then drop the pan. Don't expect it to be completely empty, though. There will be some fluid that's still below the bottom of the filter, which doubles as a pickup.
Pop
Old Jun 8, 2005 | 08:15 AM
rmilchman's Avatar
rmilchman
A plastic drop cloth under the truck is a must. Even when you think you have it drained there will still be dripping.
Old Jun 8, 2005 | 08:28 AM
johnny8's Avatar
johnny8
i have a really good mech who doesn't charge too much... i think i'll just get the sonax valve and the syn tranny fluid and have him do it... at least i know it'll be done right.. besides... i spent more than enough time crawling around in the mud when i put my gauges in...! Did i really say that just now..? man i must be getting old..!
Old Jun 8, 2005 | 09:00 AM
bigdaddyTank's Avatar
bigdaddyTank
blackclouddiesel.com is the place you want to go, they are a diesel site, not just a tranny shop, $50 with shipping, thats were I got mine. If you just do the install without flushing the tranny, it takes 7-8 quarts to fill it all back up. Mixing new with old fluid is fine as long as your not mixing synthetic with dino. Here is how I did mine. LINK
This is by far one of the best upgrades you can do, helps the tranny and makes it shift like it was supposed to.
ztodd377
25
May 11, 2009 07:13 PM
guzzle92
37
Apr 28, 2006 08:50 AM
guzzle92
Jun 12, 2005 11:59 AM
dtm1
May 14, 2005 10:54 PM
icebreaker88
Jun 10, 2003 02:07 PM
