1978 - 1996 Big Bronco
High pitched whistle
Old Jun 6, 2005 | 02:23 PM
rews2's Avatar
rews2
I get what sounds like a high pitched whistle if I go high RPM's just before I shift no matter what gear I am in or going to. If I back out of the throttle it will go away. I haven't put a tach in yet so am not sure what the RPM range is that this happens. Any ideas? Maybe a vacuum leak?
Old Jun 6, 2005 | 03:31 PM
thenewjohndeere's Avatar
thenewjohndeere
manifolds?
have you looked at your exhaust manifolds? mine will do that occasionally because i have some cracks in them ... im kinda used to it now ... ive been meaning to fix it but who really has the time, neways thats my two sents ... if it is a crack you'll see white around the cracks where the exhaust is coming out
Old Jun 7, 2005 | 10:27 AM
iagainsti's Avatar
iagainsti
do you have a FIPK or aftermarket TB installed ? I have both and get a whistle around 1700 rpm. Not sure it its one or the other or a combination of the two
Old Jun 7, 2005 | 02:29 PM
rews2's Avatar
rews2
No, nothing aftermarkrt bone stock.
Old Jun 8, 2005 | 10:36 AM
iagainsti's Avatar
iagainsti
If you put it in park and rev the motor does it whistle or does it just happen underload ? I would also check all your air intake clamps be it MAF or SD and also try cleaning your throttlebody.
Old Jun 8, 2005 | 02:16 PM
rews2's Avatar
rews2
It does whistle in neutral too, in the morning at first start up. I haven't checked my connections yet but will and let you know what I find out. As far as cleaning the TB I have used Berryman B-12 spray in the past will that work?
Old Jun 8, 2005 | 03:57 PM
iagainsti's Avatar
iagainsti
You must use a TB cleaner. Im not familar with the brand you have but if it says for use on TB's your okay. Any other products can harm your TB by breaking down the internal seals. If it whistles in neutral I would throw up the hood and try to locate the source. Start from the air filter and move your way up to the TB. Good luck
Old Jun 8, 2005 | 06:51 PM
rews2's Avatar
rews2
I was wrong it is CRC and it is a TB cleaner, I was thinking of the fuel line cleaner. I'll give it a shot and try connectors in the in the intake system. Thanks for the ideas.
Old Jun 9, 2005 | 09:23 AM
Kemicalburns's Avatar
Kemicalburns
check the hard vacum lines especially. they get brittle and crack over time. they are usually wraped up in a wire loom so they arent easy to see. if they are cracked you can replace with basic rubber vac hose
Old Jun 9, 2005 | 10:33 AM
RangerRuss's Avatar
RangerRuss
Also, check and clean or replace your Idle Air Controller (IAC). Have been known to make noises that have been described as everything from a whistle to a freight train.
Russ
Old Jun 9, 2005 | 02:31 PM
rews2's Avatar
rews2
Ranger & Kemical, thanks for the added info. I have already replaced some of the hard lines and will check the others as well as the IAC. The whistle doesn't seem to be changing performance any just is an annoyance.
Christof13T
Sep 18, 2013 10:32 AM
19687.3idi
May 18, 2013 08:13 AM
FordandCaravellz
Modular V10 (6.8l)
16
Jan 4, 2006 11:10 AM
jcawthra
Feb 11, 2005 03:57 PM
grantspopp
Modular V10 (6.8l)
Jun 22, 2003 08:00 PM
