I have a 03 super crew 4x4 and I got in it today to drive it and the power windows don't work, the power sunroof doesn't work, and the power rear sliding window didn't work and the interior lights and visor acceseries. There is no fuse that I can find and no relays that I can tell go to all those things. Thanks . mikeb2
Anyone know where I can get instructions on replacing my power door lock actuators? Both are failing on my 99 F150 SC. I've got replacements from Ford.
Thanks for any assistance!
welcome to FTE
Check out the FAQ post at the top of this forum for the answer to this and other common issues
I would start checking common harnesses under the dash and hood. Sounds like there may be 1 that has come partially apart breaking the power to the prob areas. Just go through and make sure all are connected solidly. Also look for one that may be completely disconnected.
This is a response to my 03 supercrew with the power window problems. I took all of the switches and light bulbs out after finding a burnt interior light fuse. I then replaced the fuse and it didn't blow. I then started putting accesories back together and got it all together and everything has been perfect ever since. I did find that the sunroof controler wires overhead may have been touching the metal roof above the switch and I adjusted them but I am not sure if that was it but it is fine now. The ford dealer wanted $85 per hour and said that I better expect at least 2 hours. With the money saved by not taking it to the dealer I bought a K&N filter for it.
