probs with leveling kit?
Old Jun 5, 2005 | 02:14 PM
MJEmerson's Avatar
MJEmerson
finally got the leveling kit bug....cant stand to see the lost 2.5 inches with such a cheap and easy fix.
My biggest hold up on getting it has been the worry that changing the ride of the truck will cause excess wear on front end parts by taking them out of line with what ford designed them for. any one had any probs of info on this?
also wondering if it will void the warranty on front end parts of the truck.
thanks in advance for the help.
Mike
Old Jun 6, 2005 | 04:29 PM
dleonard888's Avatar
dleonard888
I heard that it does void the warranty, anything attached that goes wrong they can refuse to fix
Old Jun 6, 2005 | 10:32 PM
Carguy1959's Avatar
Carguy1959
I've had my 2in Autospring kit on for about 10,000 miles. Tire wear is normal, ride is normal, looks, much better. As far as the warranty goes, I think they have to prove it caused the problem....
Old Jun 8, 2005 | 12:06 AM
ejpreston's Avatar
ejpreston
I've had my kit in for a while now, and it's great overall. I too was, and am still concerned with the changed geometry. Don't get me wrong, it drives fine and works great (after alignment of course). But, it brings the travel almost to full drop, and it does reach full drop over speedbumps, etc. Also, cornering at high speeds (freeway bankings, etc) seem unstable, but then again, it's a truck, not a sports car. I'm happy with mine overall.
Old Jun 8, 2005 | 11:34 AM
laglernate's Avatar
laglernate
Question
What type of leveling kit did you get because i know that the poly spring spacers will cause you to over extend your shocks. I was looking into a kit from Donahoe Racing which is a bracket that mounts on the top of the shock and drops the whole assymble down. Any thoughts from anyone?
http://performancelifts.com/cgi-bin/cart/DRE9-2500.html
Old Jun 8, 2005 | 05:29 PM
ejpreston's Avatar
ejpreston
I got that same type (mounts on top of the strut unit, dropping it all down together). That's not what maxes out its drop, it's the upper control arm that gets maxed out. It has to reach a lot lower to connect to the turning nuckle/spindle/hub. I go tthe EZ lift one made out of solid aluminum. 2 inch lift.
Old Jun 8, 2005 | 06:25 PM
MJEmerson's Avatar
MJEmerson
this is good info thanks for all the replies
Old Jun 8, 2005 | 06:47 PM
04fx4scab's Avatar
04fx4scab
that donahoe kit doesn't actually mount on top of the existing strut (a.k.a. autospring) it replaces the top strut plate with the new spacer. the only drawback is that you have to disassemble the strut to install like the daystar.
