I have a 1991 Ford Ranger, which is a manual. I can't put it in reverse without grinding the gears so I have to shutoff the pickup to put in reverse. It is also hard to put into first when I am at a stop. I was wondering if someone could tell me what the problem might be.
Things I've tried: When I pressed the clutch in, it would go clear to the floor and then when it was at the floor it would make a slight noise as long as I left the clutch pedal all the way to the floor. I checked the master cylinder resevoir fluid and it was bone dry, and no apparent leaks. I put fluid in, bleed the line, got all the air out (I think). Now the clutch pedal is working without having all the travel, however if I push it all the way to the floor it still makes that slight noise and I don't know how to discribe it cause it's real faint sounding. It still grinds going into reverse, and it's still hard to get into first. Any ideas?
It sounds like you still have air in the clutch system. With the angle the master cylinder sits (angled down). it is very difficult to get all the air out
of the system.
Um, since you had the problem before bleeding I highly doubt that you mysteriously developed an air in the system problem (I'm now assuming it was and is a normal clutch pedal feeling). With this in mind, I'd say it's a pilot bearing or a throwout bearing. The tipoff/hint here is your statement "it would make a slight noise as long as I left the clutch pedal all the way to the floor". Squeaky, scratchy, metallic sounds? This strongly suggests a failure of one of the two bearings noted, especially the pilot bearing.
