Blower motor resistor
Old Jun 5, 2005 | 07:03 AM
jqp00002's Avatar
jqp00002
Question Blower motor resistor
Anyone have an idea where I can get a good blower motor resistor for a 1991 Ford F-250. I have been to NAPA, O'reilleys Autozone and Advanced. Nobody shows it available for my truck. I do not want to go to the dealership because they will charge out the nose for it. Any suggesstions? Thanks.
Old Jun 5, 2005 | 08:42 AM
holland501's Avatar
holland501
Bone-yard.
Old Jun 5, 2005 | 12:12 PM
jqp00002's Avatar
jqp00002
How do you know if you got a good or bad one?
Old Jun 5, 2005 | 02:40 PM
holland501's Avatar
holland501
Take a VOM (volt/ohm meter) with you. If one of the circuits shows infinite resistance, better known as an Open. It's no good. Or play the odds. What are the chances of that truck having the exact same problem as your's? Good luck.
Old Sep 8, 2005 | 09:34 AM
91-Exploder's Avatar
91-Exploder
The stealer only charges about $12 for this part
Old Sep 8, 2005 | 12:30 PM
goofy173's Avatar
goofy173
You can generally just look at it and see if it's broken. If you have a 4 speed motor you'll have 3 coils. You can use an ohm meter to check for sure but if it's open, you'll see it in the coil that is broken. Because of the current draw sometimes the plug becomes corroded and the contacts on both the plug and the recept. need cleaned.
Marky48170
Sep 14, 2011 11:10 PM
mikebourg
Dec 24, 2008 07:21 PM
77 Bronco
Oct 4, 2008 12:45 AM
RBWiseman
Bronco II
18
Sep 28, 2006 08:53 PM
Dogdecur
Sep 5, 2002 11:41 AM
