Blower motor resistor
Old Dec 23, 2008 | 07:52 PM
mikebourg's Avatar
mikebourg
I have an 05 Excursion with climate control. It is suffering from the blower always on high condition. The dealer sold me the resistor pack and says that is the fix. Do the EATC vehicles have a resistor pack? If so, where is it?
Old Dec 24, 2008 | 01:16 AM
Move over I'm coming's Avatar
Easy fix
Raise your hood. Look at Rh back firewall. (passenger side)
You can see the rear of blower motor.
Look beside it there is a plug (I believe to the bottom right)
The small rectangle assembly under that plug is your resistor block.
Remove the 2 bolts that hold it to the firewall and pull it out.
Reverse proceedure to reinstall.
Then you will be cooking -w- heat again
Old Dec 24, 2008 | 07:21 PM
al52269's Avatar
al52269
Thanks for sharing info.
86eddieb
Dec 20, 2019 03:59 PM
jyates2007
Oct 18, 2015 11:24 PM
EffunFiddy
1978 - 1996 Big Bronco
Oct 29, 2014 10:08 PM
Marky48170
Sep 14, 2011 11:10 PM
drpratt
Apr 14, 2009 09:50 AM
