soft clutch
Old Jan 2, 2000 | 01:51 PM
Chris's Avatar
Chris
soft clutch
Here is my problem.
I have a '94 F150 with an I-6. My clutch seems to be giving me a problem.
On a very cold day I was not able to get into gear and it felt very soft....then it warmed up and seemed to work fine.....then it did it again the next day but took longer to warm up and it would stop working if I did not use it for a long period of time....
I have no idea what the problem could be...I had the clutch plates changed 7 months ago and have only put 5000 miles on it....any ideas??
Thank you
Chris
Old Jan 2, 2000 | 06:04 PM
F100's Avatar
F100
soft clutch
Chris,
Is it possible your clutch disc may be "retaining water," therefore, with the freezing weather, freezing to the clutch plate? That would explain why it works after the engine warms up and why the pedal would feel strange. The question is, how did your clutch disc get wet, and how do you dry it out?
Henry
>time....
Old Jan 2, 2000 | 10:51 PM
KC's Avatar
KC
soft clutch
Chris, I had the same problem with my 94. It turned out to be a bad pressure plate. It wasn't fully disengaging. When mine went bad i had a hard time getting it into 1st and reverse gear. I took it to a dealer and they replace the pressure plate. Also, have you checked your slave cyl fulid level, that too could be low. If it's low you won't get full clutch release. Good luck.
Kevin
Old Jan 3, 2000 | 08:17 AM
chris_2's Avatar
chris_2
soft clutch
The clutch fluid level is fine, but I am having problems getting into those two gears......
Old Jan 3, 2000 | 08:52 AM
Phillip Guidry's Avatar
Phillip Guidry
soft clutch
MapleShadeDiesel
44
Feb 4, 2009 04:06 PM
RubberDuck
17
Oct 7, 2007 11:58 PM
Mr.Burls
Sep 27, 2005 11:26 PM
MaxBurn
1983 - 2012 Ranger & B-Series
Jul 22, 2004 10:42 PM
cedoc
Dec 28, 2002 07:44 AM
