steering location
Old Jun 4, 2005 | 12:49 AM
tip49's Avatar
tip49
steering location
Does anyone have the measurement from inside door post to center of steering column for a stock setup 48-52 F1 ?
I am in process of locating a 90 Crown Vic column and it looks like I have about 10" from inside door post to center of column and still clear ex manifolds.. I want as close to stock location as possible. Also my mock up has top of steering wheel at about 34" to floor. I am going to use stock bracket to attach column to under dash and modify hanging brake bracket to fit as well.
Tom
Old Jun 4, 2005 | 06:46 AM
4tl8ford's Avatar
4tl8ford
Mount the column in the original location, then use borgson joints to locate the shaft to the box. Just a thought.
Old Jun 5, 2005 | 12:09 AM
tip49's Avatar
tip49
Column location
Would anyone have the measurement for what the stock height and positioning of the stock column would be?
Tom
Old Jun 5, 2005 | 01:03 AM
mtflat's Avatar
mtflat
Inside of the door post to the center line of the column - 13.5"
Floor to top of steering wheel is 35.5" (vertical height)
Floor where column comes thru to the face of the steering wheel - 32" (toward driver)
Old Jun 5, 2005 | 09:27 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
Maybe I am missing something, if you are measuring from the door post you have the cab there. There are two holes in the bottom of the dash that held the old bracket in place, they are about 3 inches apart. Did you weld them up or fill them in?
Old Jun 5, 2005 | 10:29 PM
tip49's Avatar
tip49
Column location
MFlat
Exactly the info I was looking for , thanks
I'll post pics in my gallery once I get column, brakes installed
Tom
Outlaw56
Jul 22, 2013 09:34 PM
tip49
Feb 27, 2012 02:05 PM
fluknick
21
Feb 13, 2012 06:40 PM
52 5 star
Jan 31, 2012 07:03 PM
Ziegelsteinfaust
Aug 12, 2011 05:42 PM
