my 1980 f250 has electrical problems I think. When motor comes up to temp the power cuts out abruptly, then after a breif rest period, will run again for a couple kms then expire again. lead me to think its temperature related. Anyone experience this or know anyone that has experienced this? brand new problem. i've replaced the fuel pump, spark plugs, distributor cap, rotor, coil and brain box but still no peace ??????
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
usually if an engine starts and runs fine, but dies after it warms up, only to start and run fine again after a short while, its a bad coil.
also check any ported vacuum switches to make sure they are not creating a big vac leak when they open up.
i recently had the same problem come to find out it was a plugged cat trry pulling you o2 sensor out which creats an exhaust leak and see what happens it might still die but will be easyier to start the next time around mine did it then died but fired up after a minute or too
