"check engine" indicator light
Old Jan 9, 2000 | 10:11 PM
memory's Avatar
memory
I just bought a '92 Ranger xlt 4x2,5 speed with 76,000 miles on it. Two mechanics looked at it before I bought it. Now I get a check engine indicator light that comes on periodically. Does anyone know what this might mean or should I just ignore it? Would it do that if it were overheating? My thermostat doesn't seem to be working either.
memory
Old Jan 10, 2000 | 12:33 AM
Jay's Avatar
Jay
Most likely your check engine light is on becouse of an emissions control item, 02sensor etc.
Unfortunatly you will have to take it to the shop and have it hooked up to scanner to retrieve the codes.
As far as your thermostat not working is it running to hot or not hot enough? If its running to cold maybe its causing you to run to rich most of the time and setting off the engine light.
Good luck.
Old Jan 10, 2000 | 06:42 AM
RGAZ's Avatar
RGAZ
You can get a code scanner from JC Witney for $35 and read the engine code as often as you want. A mechanic will cahrge you $50 just to check. Most likely it is the O2 sensor or the TPS. Personnally, I would replace the O2 sensor and the TPS.
BTW: If the O2 is going bad your gas mileage should drop, but if the tps is going bad you won't even notice it because the engine can run fine without it. (It just speeds engine response time at WOT)
Later.
Randy
Old Jan 10, 2000 | 10:14 AM
PAUL_2's Avatar
PAUL_2
Memory ,
You can retrieve codes from the computer with a simple jumper wire plugged correctly into the EEC IV connector . You have two diagnostic modes , engine off and running . All you have to do is connect the jumper wire , turn the key on , watch and count the number of blinks . Get and read a good diagnostic manual for your vehicle . Dont just change parts unless you know what is actually wrong ....they cost too much just to switch them based on a theory .
Paul
Old Jan 10, 2000 | 03:23 PM
rockcrawl's Avatar
rockcrawl
79F250isalive!
Oct 19, 2014 05:58 PM
Junior81
1983 - 2012 Ranger & B-Series
Apr 17, 2013 08:46 AM
mpmccarthy
Jul 24, 2004 04:58 PM
majn
Bronco II
Mar 7, 2004 09:35 PM
